How do you scan your MF Film?
drjoke
5:06 PM
I have Nikon Coolscan V ED for 35mm, and it's working very well.
I cannot afford Coolscan 9000 for MF. I have Epson V700 at home, and am wondering if it's good enough.
Scanners for MF becomes very expensive comparing to 35mm.
Will I likely have better quality with V700 on MF comparing to Coolscan V ED on 35mm?
What do you guys do?
I love that picture, Keith!
I use a cheap flatbed style CanonScan 8400f. It has a light in the cover. It handles 1 strip of MF film or 2 stips of 135 at a time.
I use a Canon 8400F. It is ok but not great, but I dont want to spend more on a scanner because my goal is to print negs and project slides (or maybe print them on Ilfochrome).
The 700 and the 750 are [Almost] identical apart from the 750 shipping with a fluid mount in some countries, here in the UK you have to ask for a fluid mount.
The fluid mount is very good, BUT rather fragile, my first one broke apart in two months and my new one is starting to crack a bit, I think maybe the scanner fluid is doing nasty things to the plastic.
It does work very well for MF and 5x4, it does 135 too but it does not hold a candle to the Nikons
Remember if you got a 9000 you could sell your V, still a big outlay though and it won't do 5x4 if you ever use that.
//Jan
Edited, I just double checked and the 750 has a different coating on the lenses, other than that they are identical.
My first attempts were not good enough, you can see the camera reflection in there
However now I got it better
All in my flickr stream
