... missing foamseals ? ...
TMLee
12:30 PM
singapore
I just noticed my ZI does not have any foam seals around the grooves on the body that receive the closing hinged back.
Is this normal ?
Hi there, although I have not personally held and inspected a ZI before, my knowledge from the reviews of it online is that the ZI was built using a labyrinth design which blocks out light , without the need for any foam to be installed.
That's correct. The Zeiss Ikon is a German camera, although it's made in Japan.
And like nearly all European cameras, the back is designed so that it doesn't require any light-blocking material, such as foam.
Most Japanese cameras aren't adequately designed to block light and require foam to complete the job. You wouldn't think that 1mm or 2mm of foam would make a difference, but when the foam deteriorates, it's very common for light leaks to make their way onto film.
I'm a bit surprised that Japanese camera makers didn't revisit the camera back design and correct this, especially after it became apparent that foam has a limited service life.
Tks guys,
appreciate the prompt feedback.
Now I have to figure out why some frames of my first roll with this ZI showed light leaks !!!!
(fear and trepidation now....)
Is it a ploy to get you to buy a new camera after 10 years or so. With digital they don't need to do this as a camera has a production life of 1-2.5 years before a improved model comes out.
I can't see into the minds of the Japanese designers, but I suspect cost and ignorance had more to do with it. Foam costs less than the extra metal needed to make a light tight design. And I expect nobody really realized the foam would deteriorate as quickly as has been the case.
Tks guys,
The ZM does not use foam seals except around the film cartridge window...where 99% of light leaks occur. Check that out first.
As far as I am concerned, tape that window black...don't you remember what film you've just loaded and already set the ISO speed? Why do you need to know until that roll is finished? 🙄
OR, how many ZM's do you carry?
