Morca007
Matt
I bought this Nokton 50 about two months ago, but didn't get to use it (moving complications) until this past weekend. I am quite happy with it and glad to finally be using a modern lens instead of my Jupiter-8.
Compared to the J-8:
-It is much larger and heavier; With the shade on it blocks about 25% of the 50mm framelines on my Bessa R.
-Much better flare response.
-Sharper/More contrasty.
APX 400 @ EI 320 in Diafine:
Probably the only roll of APX 400 that I have actually liked, and the first I've exposed at under box speed.
Arista Premium 400 (Tri-X) @ EI 640-800 in Diafine:
I should probably rate this stuff closer to 1200.
Processing notes:
Developing- Twist agitation every thirty seconds.
Digital capture- Scanned on Canon 8600F flatbed at 1200DPI with as little correction applied as possible.
Photoshop- Crop, Levels adjust, Dust/Scratch removal, resize.
Processing notes:
