Muggins
Proprietor of Orphanage for Lost Cameras
I've just got a Kodak Duo 620 (less than 24hrs after deciding that future cameras should be one a one-in-one-out basis... 😱), the second non-art-deco model. Having checked that the bellows looked OK from the outside - more on that anon - and the shutter worked, I found when I got it home that the rear lens in the pop-up viewfinder has gone awol so that the view is pretty much what you'd get if you drank a bottle of scotch before you looked.
Does anyone have a donor Duo 620 or a similar Kodak that I could get a replacement lens off, please? I'd like to have a go at using it, especially as it still has a roll of hardly-started 620 film in it (that's why I only checked the bellows from the outside). Probably utterly useless by now, but I wonder if the absence of the viewfinder lens is why the film is still unfinished?
Also, anyone ever taken leather off one? There are some spectacular Zeiss bumps (Nagel must be spinning in his grave, hearing me call them that!) where the brass rivets are corroding, and I'd appreciate advice on whether or not you can treat them.
Many thanks,
Adrian
Many thanks,
Adrian
