40mm Nokton + R2A
taffy
10:08 AM
Does anyone have this camera and lens combo? I just want to ask how you manage with the frame lines?
Thanks!
Taffy
Hi taffy.
I haven't a Nokton but I use my Summicron C 40mm f2 with my r2a with 35mm frameline. I have found 35mm frameline better than 50mm one.
I hope it helps, but you must try both framelines in order to find wich is better for you.
Xavier
Hi taffy.
Xavier
do you have some shot made from same position with summicron and jupiter 8 for example. im interested to see how big difference in FOV is...
Please, let me some time to search these kind of pictures. I'm sure I have because we made a lot of tests when I bought the Cron but I'm almost sure they are not scanned.
Best regards.
Hi Taffy,
I have the 40 Nokton on an R2M and usually use the 50mm frame lines and and just take it for granted that I have a little extra room left in the frame. But most of the time I don't worry too much about framing accuracy anyway. As long as I can crop if needed.
Randy
