scottyb70
I bought some Kodafix Solution, Photo Flo and Tmax developer from a garage sale about 6 months ago. I kept the solutions in my closet and I don't know how old they are. The kodafix has a slight yellow milky appearance with a little bit of sediment at the bottom of the bottle. The photo flo and tmax are pretty clear in color. Should I try to use these liquids? The temperature in my house is about 60-64 degrees, but I have a utility room that I can close off and warm up the room with a heater. Would this be the best way to do this or can I warm up the chemicals near my furnace?
I also have a changing bag and I am using a plastic omega developing tank. The instructions for the developing tank states I can use the shaking axle which makes two simultaneous movement rotatory and vertical to spin the reels as opposed to tipping the tank. Is this a good idea? I was going to use distilled water instead of tap water for mixing and rinsing, is this a good idea?
I will use either Ilford 3200 or FP4 Plus 125 Film.
