Sparrow
I’m about to put a modern panchromatic film in a 1930’something Bessa that I just “serviced” will the red window fog it do you think?
Any other advise?
Any other advise?
Thanks, the last time I used a camera with a red window it was a Kodak, made of Bakelite! so I'm a bit rusty
Any other advise?
LOL Sounds like me. And old Brownie?
mixed veiws it seems-Some people for, some against
I'm with Victor, absoloutly, (although i havnt had light leak through the paper-yet, but then i rarely have ever given it chance to). not including the poor thin backing released on some on the efke, the paper is only designed to stop the light going through it and onto the film (for whatever that safe length of time may be), but its not an all encompassing light trap for the whole back.
the old film used in early cameras wasn't affected by red light. many of the old darkrooms had red coloured material covering windows rather than working in complete dark as is necessary with modern films, for the same reason the cameras used the red windows.
if the camera has a sliding cover its there for that reason-to stop light entering and bouncing around the inside and fogging the film (more impotant as the film speeds increased). Sparrow's bessa sounded like (in the other thread) one that had the knob to close the windows and if you look on the inside of the bessa (and a bunch of other cameras) you can see the paint, whilst it isnt glossy, it isnt exactly matt non reflective finish either. furthermore, there are no light traps behind the pressure plate or red windows (felt or otherwise as on some cameras). the red windows on the 6x9 is are close to the top, not center of the back as 6x6 is (so the light bounces around behind the pressure plate and off the insides of the back until it gets to the film.
so if the back is exposed to a reasonable amount of light for any lentgh of time you will inevitably, sooner or later get some fogging. it was common instruction of the day to turn your back to the sun or to wind on in the shade, and i think still hear people repeating it nowadays it was so commonly known
i would suggest it is a mixture of circumstances why many people arnt getting film fogging in red window cameras ,modern or box brownies (short answer is freakish luck 😱 because old red window cameras designed for ol ortho film will leak using modern film, without putting tape over the window)
modern ones should have a light trap of some kind, although if we are talking holgas, i hear they are full of light leak occurances, not known how many are from the red windows though,,and any decent camera is going to have a sliding door. people lucky with old box brownies maybe because the inside is flat black cardbourd or they just havnt been exposed to much direct light
If you're worried, put a piece of black insulting - sorry, insulating tape over the window, and only lift it when you wind on.
Apart from a dodgy batch of Efke where ALL the markings on the paper came through on the film, not just the numbers, I've never yet had a problem.
Adrian
That must have been a bad batch. I've used a lot of Efke, in several red window cameras, and I've never had that problem.
You should be all right. Many cameras have red windows without covering lids, an example is the Isolette V, and I have quite a few of these. They are designed that way. So, good ahead and shoot.
My 1935 6x9 rf caught some light ingress from the red window. It has no cover for the window, so I did as suggested here and covered it with black tape.
It still let light in when the window was uncovered, which was getting round the side of the pressure plate from the back to the sides between the spool and plate. I blocked off this light with foam around the plate.
Just uncovering the window to wind on was enough to catch a leak.
