R
ruben
Guest
Hi folks,
I badly need your advice.
I am assembling a small medium format system on the basis of the Pentacon Six mount, which in my case will use the Kiev 6c camera and the Pentacon Six camera.
The wide angle lenses I have bought is a Carl Zeiss Jena Flektogon 50mm, which is supposed to give a decent performance - not a superclass market crushing best seller. According to the situation of the lens, it is sold between 100 and 300 dollars. Ok, 350.- no more. But remember we are in a period of low prices for many medium format lenses and cameras.
My problem is that the outer surface measures 86mm, and has an almost unexistent thread for filters - meaning that the outer glass is VERY prong to accidental finger greasing and other dangers as well. Therefore a protective filter is due, as well as a metal cap.
We all know that filters should not be lower quality to the lens quality. My question is nevertheless, if in the case of an UV filter we can make exception, due to the transparency of the filter glass and go for a $12 cheapo Chinese UV.
I have no option of no adding a protective filter, that will have to be renewed from time to time, according to the use of the lens. So far the outer glass of the lens looks without a single streak.
Ruben
Ruben
