THE lens
Bill Pierce
12:01 AM
Truth is, while rangefinder lenses from 12mm to 135mm are easily available, folks often travel light with a rangefinder - one lens on the camera, just maybe another in a pocket.
I wondered what lens is that number one lens - and more important, WHY #1 - for various folks here on the forum.
When I first started shooting professionally, like many journalists I stuck to the 35mm lens. Then one day Burk Uzzle and I switched cameras to take pictures of each other. That way we each ended up with pictures of ourselves on our own film (not too egocentric). I picked up Burk's camera and yelled, "What is this lens?" It was, compared to what I was use to, a modest telephoto. It might take a little more effort to compose an image compared to the "get it all in" 35, but that very effort could make for a better, stronger picture. Burk said, "It's a normal; it's a 50." From that day on, I was a 50 user. Now, with the M8, I use the 35 as a normal. But someone (and please check in a give yourself credit) pointed out that the safety margin in the bright line finder of the first M8 actually made a 40mm lens (which brings up the 50mm frame) frame line a good choice and more accurate at normal distances. It works out to the equivalent of a 52mm lens on the 1.3 frame M8. I've ordered one from Cameraquest. And I hope it will be my new "normal" on the M8.
Once again, what's THE lens on your camera when you head out the door and WHY?
Bill
Bill, I use both a 35mm and a 50mm on my Leica IIIf, for different reasons. Some of my favorite subjects are airplanes, often displayed at airshows. I find that, if I back up enough to frame the plane with a 50mm, people will invariably walk between me and my subject. For that reason, I choose a 35mm which works fine, but closer to the subject.
For digital photos, I can't afford an M8. I have an Oly E-510 which I bought with a good quality Zuiko 14-54 lens. The combination works fine, but is a little cumbersome for walk-around shooting, looking for quick shots. For that, I acquired a Leitz Elmarit-R 28/2.8 to serve as a prime, manual lens. At an effective 56mm equivalent on the E-510, it serves me well.
Jim N.
Depends upon what I'm shooting.
If I'm just going out, nothing special to shoot, I'll take a 35. I like that focal length better than a 40 or 50mm.
If I'm going out to do air-to-air, which is a paying gig, I'll take my 28-135 which on my Canon digital is a 45-210. Covers all my bases for me.
50mm for me at home. It helps exclude extraneous visual elements.
35mm on vacation, because things are more interesting there than here.
For me it's always been a 50. I've tried to get on with other focal lengths but it never happens for me.
Usually when I see something of interest, it'll fit in a 50mm frame, perhaps with a few steps back.
Wide angles don't work for me because I tend to do a fair bit of candid portraiture and don't like wide angle portraits very much. I also tend to struggle to find stuff to fit into a wide frame.
Longer lenses don't work for me either. They're too tight for most of my shooting, and for portraiture I find I have to move too far back from my subject.
I only own one lens right now, a 35mm f/2 Biogon. With a 50mm I often found myself taking a step back. With the 35mm it usually forces me to take a step forward.
Maybe a 40mm would be perfect, but for now I'm really just trying to master the 35mm focal length.
I like the 50mm lens, as it is the lens that I always had on the 35mm camera and I feel very comfortable with it.
I make it work and there is
no surprises, and that is fine with me.
Before recently it was a CV 25/4, now it seems to be a Nikkor 35/1.8. The 35 allows me to get close without distortion. While the 25 is pretty good distortion-wise, it's not the lens you want to put a persons head in the corner of the frame. 35mm just allows me to get close, SCUFI (Shoot Close Up For Impact). I try to fill frames with the image, partly because I used to shoot slides, partly just to me format is an important part of the process.
B2 (;->
at first it was a 28...Pure Street magic
then I moved to a 35 PURRfect really
but for some reason NOW.... its the Intimacy of the 50
All the Best- H
With my rangefinder, this is often my CV 21mm. Yes that's right, a 21. When using it, I shoot with the mindset of apprehending space, whether that space is large or small.
With my Nikon F3, my favorite lens is my CV 58mm SL-II. I love the slightly longer than normal perspective... I think for all the reasons that Bill states he took up shooting with a 50mm.
If you know where you are going and under what conditions you will be photographing you should plan ahead with the appropriate lens(es) and film(s). If on the other hand you are going out to have a good time and photography is secondary take whatever camera you want.
