whitecat
Lone Range(find)er
Any rampany roumors out there?
They sent me a prototype for testing. Noise free at ISO 25,600.
I dont count on anything coming. Sensors still are not there yet for what a rangefinder needs.
How about the FF sensor used in the nikon d700? Would that work, its good at higher iso. It only has to be the same size as 35mm film and sensitive to light after all.I dont count on anything coming. Sensors still are not there yet for what a rangefinder needs.
And that is what Leica marketing and associates want you to believe. 🙂
With the true 16bits/color in the new sensors there is enough room to correct for vignetting, at least of moderate (21mm and above ?) wide angles, and to end up with a decent dynamic range - at least as good as the M8's.
If making a FF M9/ZI or other has business appeal is another question.
Roland.
It is all comes to market and profitability.
The FF D-RF market is small anyhow and (up to now) happy with film.
I assume a digital ZI should cost about $3500, and FF might be even higher than $5000
That is a lot of money.
In light of the marketing story of the M8, I don't think Zeiss/Cosina will get into such an adventure.
(But then, again, Epson did. So... I don't know)
If such a camera had been there, and I had the money,
I would have definitely bought me one.
I think you are right to a point, except I don't think any non-mf maker offers 16bit output and there is good reason to believe that 12 would be enough for almost all dslr's.
Mike
One could just put a Voigtländer 15/4.5 SL lens on a Nikon D700 and try it out. The lens is the same, and the sensor is full frame.With the true 16bits/color in the new sensors there is enough room to correct for vignetting, at least of moderate (21mm and above ?) wide angles, and to end up with a decent dynamic range - at least as good as the M8's.
