21mm Super Angulon
TJV
10:55 PM
Cloud Nine
What's a 21mm Super Angulon worth these days? I see just about all of the ones on ebay are selling by Photo Arsenal and we all know they inflate prices.
Of the two versions, f4 and f3.4, what are the prices at various conditions?
I'm still into the idea of the ZM 21mm C Biogon but the Super Angulon seems such a well regarded lens.
Thoughts?
About prices, a very nice looking copy (with original hood !) of the 21/3.4 just was just recently here in the classifieds and sold for about $850.
The 21/4.0 is the older (first) version and was made in both, screw-mount and m-mount. Not that great optical performer but sought-after by the collectors. The following design, 21/3.4 was only made in m-mount but for a quite long time. It is nearly free from distortion (symmetric design) and has a fantastic center-sharpness. Strong vignetting in the corners is the price to pay for this design and lacking TTL metering (the rear element blocks the meter cell).
I like mine ! 🙂
$850!!! 😱
Arsenal are selling them for about $1300!!! I'm not sure what the majority of people here think, but, for getting the metering issue, which is the better lens between the ZM C Biogon and the Super Angulon f3.4? I'm guessing if I have a kit with only modern lenses the Zeiss would be a better contrast and signature fit?
I like mine ! 🙂
If you have a kit already (!) only consisting of modern Zeiss lenses, the choice is obvious: Go for the 21mm C-Biogon ! 🙂 Cheaper (?), allows TTL metering, higher corner sharpness, and less (or no ?) vignetting.
In case, the 35mm Summilux pre-ASPH, 40mm Summicron-C, 50mm Noctilux, 75mm Summilux-M are lenses you like, the SA would be my recommendation.
At the moment I have only Leica lenses, being all new series 50mm Summicrion, 35mm Lux ASPH and 28mm Elmarit ASPH. I've never shot ZM lenses but they sure feel great and are lighter on the wallet!
^^ Your setup says "Zeiss C-Biogon 21mm" 🙂
The Super-Angulon-M shows very very good center-sharpness and not so well defined corner sharpness but that is different to the characteristics of the lenses you already have.
The 21 S-A is one of the classic Leica M lenses. It is also one where the hype is to some extent justified - it is still a very good lens. So, there is a bit of fall-off at the edges, but that means you never have to edgeburn a print! With a camera like a M2, some Tri X and a couple of red/orange filters - it can do great stuff.
However, if you are looking for images with a modern look, it is not the choice - and truth be told, shooting slides with the S-A can be a bit disconcerting with the dark corners. Here a lens like the C Biogon 21f4.5 is a better choice - and it will work with a metered camera too. Dont discount the compact VC 21f4 either. It falls midway between the S-A and the C Biogon 21f4.5. A bit of edge fall off (though much less than the S-A) but very straight rendition and truly sharp. Some people find it a bit contrasty with color, but in bl/w I haven't had a problem with that. It is also 1/2 price from the 21/4.5 and tiny. It can rattle around in your pocket until you need it.
TOM A. OR GABOR
Question:
Is the 21 SA 4. version
as sharp in the Center as the 3.4
AND is the Vignetting MORE OR LESS on the 4
because I am going to purchase the 21 SA
and DECIDING Which one...
I Want lots of Atmosphere,Center sharpness Major Falloff & Lots of Vignetting PLEASE....😱
Thanx in advance....Best-H
Helen, if you can find a clean 21f3.4 go for that one. The center sharpness of that version is among the best ever! When Leica made the first ones of these back in the 60's - they were sent to the microscope division for testing and came back with the note "There is something wrong with our equipment - it shows center sharpness approaching the theoretical limits" Supposedly Leica's note back was " Good, that was we were aiming for!".
The 21f4.0 is nowhere near as good. If you are looking for a screw-mount 21, you are better off with the Voigtlander 21f4.0 instead (and it also uses 39mm filters).
The 21f3.4 can be tricky initially, the edge fall off, the somewhat cramped fit of the aperture ring against the hood and the odd 48mm filter size - but once you see the negatives - all that is forgotten!
Look for one with a # above 2 500 000. Schneidar/Leica changed the coating slightly and it did improve the quality somewhat. Not a major step, but just enough that it is visible in contrast.
Of course, the true master with this lens was Jean Loup Sieff - goggle his site and drool!
For some reason a lot of companies settled on the 49mm filter size, yet Nikon, Leitz, and Canon all produced lots of lenses taking 48mm filters. Helen, you also might check out the 19mm f/3.5 Canon in LTM if you run across one. It has a signature very similar to the f/3.4 Super Angulon.
When I sold my Leica kit the 3.4 was the largest regret. I don't know the serial # and whether I had the later coating, but Kodachromes were beyond special and TX in HC-110 was magic. I didn't mind the fall-off on chromes, but with monochromes it is perfect. Tom is spot on with this ... not that he needs any confirmation from me.
I just picked up my SA 21/3,4 today and will soup the results later tonight. It has been a cold, clear and sunny day in the Lowermainland...so i am hoping to see some of the SA's characteristics.
Thanks to both Gabor and Tom A for their postings on the SA.
To me the 21mm Super Angulon is a special kind of lens. Mine has produced some of my best images. The only magazine cover I ever sold was a 21 SA shot. Another time while traveling in India was able to get access to the crypt beneath the Taj Mahal. Just time for one frame wide open on Kodachrome 64. Was loaded for bright sunlight and never expected to get a chance for such a shot.
Occasionally while shooting contra jour, I've had an unusual type of flare show up. It looks like bars of a rainbow and in some cases can be quite attractive. Have tried to reproduce the effect but it happens very rarely.
I don't have much luck posting images on RFF so will just provide links in case anyone has an interest. All were shot with 21mm Super Angulon (Later f/3.4 version) on an M4.
Beneath the Taj..
http://www.indiamike.com/photopost/data/500/TajCrypt.jpg
Hanging out with the hippies in circa 1970 Kathmandu..
http://www.indiamike.com/photopost/data/508/Secret1.jpg
http://www.indiamike.com/photopost/data/508/KathChillumCirc.jpg
Street...
http://www.indiamike.com/photopost/data/508/HopScotch.jpg
http://www.indiamike.com/photopost/data/508/KathPots1970.jpg
http://www.indiamike.com/photopost/data/500/WindowTwo.jpg
A weird flare shot.
http://gallery.photo.net/photo/3879692-lg.jpg
Wheeeeee!
http://gallery.photo.net/photo/4593329-lg.jpg
http://www.rangefinderforum.com/photopost/data/500/TahitiKetch_1.jpg
http://www.rangefinderforum.com/photopost/data/500/Groovin.jpg
I bought my 21 new in 1970 for the grand sum of $363 and think that included finder. What a deal! 🙂 It's a lens I'll never sell.
Glenn
Glenn, I like this one a lot:
I love the look of all of your examples but I worry, like you mentioned above, that the SA 3.4 might not fit in with the rest of my kit. I once tried a beautiful V2 50mm Summilux and was quite shocked at it's rendering compared to my modern lenses. Another alternative to a 21mm, forgetting for a moment the price, is Leica's new 24mm f3.8.
Well, you have some alternatives regarding "modern"... 🙂 The 21mm Zeiss lenses and the Leica 21mm Elmarit ASPH. I still think that the 21mm C-Biogon fits your needs best, though.
i tried the SA 21 and I have to say i liked it a lot. I know I will regret selling it (and I am...) but I need a lens that would work with both classic leica bodies, as well as the ones with meter. So I went with biogon-C 21/4.5. I have yet to try it out.
The Sieffs are cool. The photos that really make me covet this lens are Glenn's and Gabor's though.
Glenn
ADORE your 'smoking' Hippie Shot and the two people standing at the arch....Charming
Gabor
Beautiful Landscapes .....love the subtlety of the rose/pink hue
and the Cold Austereness in the B&W
I'm Drunk on the SA.....
