notturtle
I have a couple of lenses with slight slack in the focus ring and one has a touch of wobble in the front section. I have heard that a small flange accessible from the rear of the lens is the culprit. Is this the single flange that can be seen from the rear of the lens with two little notches in it (one on each side). I see other concentric circular matal components but this is the only thing I can see with nothces for a wrench.
What sort of wrench does one need and where might I be able to get one (assuming this is not prohibitively expensive). I am trying to avoid sending them off and losing them for a few weeks and paying for someone else to tighten them up.
The gap between the flange and the barrel appears very tight... v hard to get anythying in there so I cannot even tell it it is loose.
