hyperfocal infinity mark
mojobebop
1:40 PM
nyc
i'm assuming when one focuses using the 'hyperfocal method'
one would line the infinity mark to f-stop using the center of the infinity mark.
i realised it makes a difference of a foot or two.
this may be obvious, but i just wanted to be certain, as i've been using
it dead center.
thanks,
Hello mojobebop.....
That is correct. A good practice is also to align the infinity mark next to the next wider f-stop mark "just to be sure" when infinity must be absolutely sharp.
Example: Shoot f16, align infinity to the f11 mark.
sorry, but do you mean to move the mark to the left,
just so the end of the infinity mark touches the wider aperture?
And if you are really interested in a sharp horizon, then forget about this hyperfocal compromise and set the camera to infinity while - at the same time - closing the lens down to about 3 to 2.5 mm opening. (look into the front of the lens to make sure) That will give you the most pleasing sharpness. NOT the hyperfocal one, definitely not that one.
But do try it both ways on the same landscape shot and learn for yourself.
yup
yup
I often set to infinity for anything past 30 ft or so.
