Anyone happy with the CV 28 F2/M8?
SteveRD1
5:11 AM
I sold my Leica 28 Elmarit ASPH to fund a 28 Cron but silly me...I saw this CV 28 F2 for a fraction of what a used cron would cost and had to try it out.
It arrived today but man, my first impression is disappointment. Soft corners, dull color, flat looking images, vignetting, and not very sharp IMO. My Elmarit killed this lens in every area.
I needed a faster 28 for some even shooting I have coming up and it does not appear that this one will fill the bill. I will do a bunch of shooting with it all week and see how it does in the real world, but I have my doubts after seeing the first shots I took with it.
Anyway, is anyone here happy with the CV 28 F2 on the M8? If so, do you have any pics to share?
Thanks!
I think yours might have a problem, the general consensus on this lens is that it is up to par with the big boys on many levels. I had the opportunity to play with the older 1.9 28mm voigtlander once on a fellows m8 at a photo exhibition and that was already very nice so I think you might have a dud.
There is something wrong with your Ultron.
I tested the CV 28mm Ultron f/2 against the Leica 28mm Summicron f/2 and they were surprisingly close (I dare say dead-even wide open). The CV falls off (not just in the corners) when stopped down while the Summicron remains consistently sharp at all stops. Other than the slight differences in color rendition, the Ultron remains substantially contrasty and is still a serious contender at roughly 15% the price of a Summicron. If I didn't already have the Summicron, I would have been perfectly happy with the Ultron.
I would suggest returning your Ultron to the seller for a refund or replacement.
Slight vignetting wide open is normal - even the Summicron does that.
Thanks guys..may have a dud. I will try another before throwing in the towel on it because if it is close, it is a huge savings over a cron (though I know the cron is the holy grail in a 28 F2 lens) and I could use all of the savings I can get. Thanks again...
If you're using the lens on an M8, do not return it until you've tried it with an IR/CUT filter.
The Ultron I tested was 6-bit coded (as a Summicron) and I used a UV/IR CUT filter. If you are not at least using an IR/CUT filter, I would suggest what you may be looking at is the cyan shift in the corners (not vignetting).
The more I think about it, the more I think this is your problem.
Try the IR/CUT filter - I am sure you will see a noted improvement. Once the mount is coded the firmware will adjust the color banding from center to corner.
Contact John Milich - JM [at] milich [dot] com for information on coding the mount (last I knew only $25 - shipping included).
Filter
Filter
I do have an IR filter but when its on the corners are CYAN as its not coded. With it off, I just have the standard vignetting BUT here is what I think happened.
I have been shooting my Elmarit ASPH for 2 months, almost daily. I was so used to the files from that lens being sharp and snappy and when I saw the 1st around the house shots from the Ultron they seemed dull, flat and soft BUT only because I was used to the Elmarit ASPH.
I have taken many more shots..outside, inside, low light, bright light and this lens renders in a totally different way than the Elmarit. I suspect more like a cron.
So after I took more shots and processed a few RAWs it is growing on me, and I am enjoying this different look. For landscape I can see the Elmarit being much nicer, but for people I can see the Ultron coming out ahead.
Sorry for my early negative rant, but I think it was just my mind not being used to that different look after seeing Elmarit shots day in and day out!
I'll see about coding it through John. I also saw some kit at popflash to code. Any experience with that?
Anyway, I think the lens is fine and here is a quick JPEG mirror shot at F2...
BTW, I did a quick test for focus shift (just a quick, sloppy one) and found none at all so far - Took some test shots at F2, 2.8, 4 and 5.6 - At 2.8 it is sharper than F2 for sure, and at F4 it seems about the same as 2.8.
Ill end up putting all of my samples and write up at my site in a couple of weeks or so. Anyway, thanks again for the responses.
Steve
Steve:
The coding kit at Popflash will do fine. The device perfectly lines up the six-bit "block" where the lens needs to the coded. Use a sharpie, or some other permanent black marker (only the black marks need to be used) - recode periodically as the ink wears off.
Personally, all of my lenses are permanently coded by either Leica or John Milich.
Steve:
Yes the coding kit really works nice. As a side note, it's reported the CV 2.0/28 AFAIK does have a flange with a circular recess. So the ink may not wear off quickly.
Regards
Ivo
More testing..
More testing..
I went out today and shot some subjects that I shot with my Elmarit, and no question. This Ultron is SOFT in the corners where my Elmarit was sharp as can be. Also, it is much softer in the center at all apertures than the Elmarit. I guess the question is, how sharp is the summicron?
Here is a quick compare, just web sized but you can see what I mean. The 1st shot was taken with the Elmarit a few weeks ago. The second with the Ultron. Look at the bottom and the corners as well as the tree on the side. It is pretty soft on the Ultron and both are at 2.8.
Is this normal behavior for the ultron or do I have a bad copy?
Elmarit ASPH at 2.8
Ultron at 2.8
Here is a quick shot where soft corners dont really matter, at F2
If the soft corners and soft overall IQ at 100% is normal for this lens I may keep it for portrait/street and pick up another Elmarit for my landscape/building shots as it excelled at that. Or I can return the Ultron and go for the 28 Cron as I was originally going to do.
Not sure...
In my limited testing of the Ultron with the Summicron I can't say the differences were all that dramatic. Once again, the most obvious differences were in color saturation. However, the Summicron is certainly sharper than the Ultron stop-to-stop (they are only comparable wide open). Also, keep in mind you're comparing a high performance German sedan to a Toyota Corolla.
Reserve final judgment until you have tried the Ultron 6-bit coded (the kit isn't a bad idea particularly for this case) with a UV/IR filter. And I wouldn't completely rule out that you might have a bum copy of the Ultron.
The Ultron does indeed have the recessed mount, so the “sharpie” coding should last for some time.
OK..link to full size samples at F2 and F8
Just want to make sure this is normal as it may be with this lens. Wide open, the bottom half of the frame/corners is soft. By F8 they are much better but still not 100% crisp, but that is fine.
If this is normal behavior at F2 for this lens then I know my copy is fine, and that it is just how it is. If so, I will probably keep the lens as the price was good, and I am finding that I am liking this lens for people, and I can shoot my barns and landscapes at F8 if need be.
Anyway, here is a link to a full size shot at F2 with soft bottom corners:
http://www.pbase.com/stevehuff/image/111610004
Then one at F8:
http://www.pbase.com/stevehuff/image/111610001
Anyone that shoots this lens with an M8, let me know if this looks normal for this lens. It seems when wide open, it is soft at the bottom 1/4 of the frame but not really the top.
I noticed that your Ultron looks softer at bottom than top in that Hospital photo, but some more testing where the subject matter is about the same across the field would be more definitive. From that photo and from what you say, I'd suspect there's something wrong with that Ultron. Maybe send it to importer CameraQuest for a look-see.
I have had the Voigtlander Skopar 28 and now happily use the Summicron. Both of those are great lenses, but the Summicron has the speed and is widely considered the best 28 for the M8.
Your lens is fine.
Looking at the pics in post #11 the corners are out of focus because you're shooting at f/2 (the corners fall outside of the DOF plane for f/2). The bottom shot of the flowers reflects this as well. The objects that fall into the image plane for f/2 are in focus (even in the corners) - see the bottom left. Everything is in focus in the top shot of the hospital because everything falls within the DOF plane for f/8. If you shoot a flat surface, such as a target, you will find the entire image field will be in focus at f/2.
You know, I thought that myself about an hour ago. I realized the shot of the antenna on the roof was at F2 and the bottom was OOF not soft. My mistake. Anyway, I shot the lens quite a bit today and got many keepers and I really do like the lens.
The hospital shots above..the top one was at 2.8 with the Elmarit and the bottom with the Ultron at 2.8 and that one does show some soft corners where the Elmarit shot does not.
Still, I am liking the smooth look of the files, and the lower contrast compared to the Elmarit for everyday real world shots. Ill post more later in the week, but after going through all of the shots I think I will be keeping the Ultron and for now will buy the coder kit.
Thanks!
Steve
Elmarit ASPH at 2.8
[deleted]
Ultron at 2.8
[deleted]
Not sure...
The two copies I tried were like that, if not worse.
Sent them back and got the Elmarit instead.
Uwe
I've now tried two copies of the CV 28/2. They were essentially equal, and both disappointing. They matched your description in most regards. They had better contrast than the older 28/1.9 but both noticeably fell off to the corners and showed unacceptable focus shift on stopping down. Flare was better controlled in the new lens but not up to Summicron standards. The focus shift of the 28/2 CV is not as bad as on on the CV 35/1.4, but it is certainly beyond acceptable dof.
The difference with respect to the Summicron 28 is very noticeable and makes the CV lens uninteresting for use on M8's. My results paralleled Sean Reid's quite closely.
CV has (had) an excellent 28mm lens, the 3.5 but the attempts to match the Summicron have fallen short.
Henning
While I like the Color Skopar, I am very happy with my 1.9, Henning. Just because there is a new 28/2, doesn't mean it has to be used. Both Puts and Reid had only good to say about the old Ultron, and I'm always surprised that not more people use it still. Here is a reminder about Puts 1.9 comments:
EP (about 28/1.9) said:
At full aperture the lens exhibits low to medium contrast and definition of very fine detail is soft but very even over the image field extending till the corners. The extreme corners are very soft. Even finer details are resolved in the center, but rapidly become softer when going to the zonal area. There is no astimatism and only a very small amount of curvature of field. There is some barrel distortion, but quite small. At 2.8 the overall contrast improves and at f/4 the optimum is reached. After f/8 contrast lowers again and from there we see a softening of image details with every additional stop. This is usual behaviour. At f/4 we note a resolution over the whole image area of above 100 lp/mm. As a design philosphy this lens is a bit tuned to high resolution versus high contrast. Mechanically this lens is excellent: no decentring at all, collimation at zero.
The Leica Summicron 28 has the advantage of superior mechanical engineering and materials. It also sports a visibly better imagery at wider apertures. Wide open there is no contest: Leica is still the one to beat. ... Stopped down it is a draw. The Ultron 28 is one third of the price of the Leica and delivers excellent, and close to outstanding imagery. .... To get some perspective: an older 28mm lens from Leica is blown to pieces by the Ultron.
While the Summicron is still the one to beat, the Ultron delivers quality, that was unbelievable some years ago. Leica designers are challenged!!
Where lenses today differ is in the mechanics, and the engineering quality and the performance at the wide apertures. But lenses are at such a high level that the user and the choice of film and the handling of the imaging chain become more impartant than ever. The most important factor now is the user expertise and expectancy. The Ultron is an amazingly good lens, that will satisfy the demands and expectations of many a photographer.
This is quite a good review for a 3rd party lens from somebody like Puts. And it matches my experience.
Roland.
BTW, I have done a ton of testing and have found ZERO focus shift with this 28 and my M8. I am a bit disappointed in the softness as I do not consider this a sharp lens by any means, but so far I actually like it in real world shooting.
I have shot at every aperture looking for the focus shift and have not seen it at all.
F2
F8
F5.6
