paul beard
Yes, that's the second catch. It is spring-loaded towards the speed selector (i.e. to the right as you hold the camera normally). I don't recommend taking it apart since you'd have to remove the RF/VF block first. The little cam under the slow-speed mechanism pushes that flat bar to the left at the end of the time and so releases the second curtain. It doesn't move very far at all, couple of mm. Taking the slow-speed mechanism out means that catch never gets pushed aside, so the second curtain cannot release.
Ah. can it be moved manually (to the left, not front to back? That might account for some of my confusion)? I didn't mess with it yesterday, thought I would give it a rest but fortified with this, I may take it up again.
Thanks.
