kemal_mumcu
I have an M2 and I find the OM camera a great companion to Leitz. Close focus and the ability to mount long lenses are reasons for an OM yet it is still very much simple and mechanical in nature. I was surprised when my M2 came to find that it was actually a bit huskier in size than my OM3. The overall dimensions of the OM are greater than the M because of the mirror box and prism but the body itself is slimmer. The OM3-4 models have a wonderful spot meter that I use with slide film and with tricky lighting. The M holds down b&w work. I've used the OM just by itself metering scenes trying to learn about light variation, trying to improve my lighting judgement for when I use b&w and "sunny 16".
The OM3ti version is actually the better model and it is cheaper to boot I believe. When you loose power the only thing you loose is your metering, the camera keeps going. I would compare the OM3s to the M6 or MP but with a good spot meter thrown in.
I turn my camera off by pulling the batteries. 🙂 Its the only way to completely avoid battery drain, at least with my model. I keep the camera on B when not in use but pull the batteries when not using the camera for a while. I get about 4 rolls average per set of batteries this way.
