Ronald M
Aside from some developers that provide some unique charactoristics like edge effects of Rodinal, or stand developing, agitation has to do only a few things.
Provide fast even wetting of the film initially. The wet /dry edge has to start and move across evenly and rapidly with no stop/start or retreat.
Provide enough flow of developer to remove developer by products so there is no streaking.
Use a technique so the whole of the film surface is refreshed. If you have so called "surege marks", the scheme you are using is not vigorous enough or you are settiing up a pattern so some portions of the film are not refreshed.
Agitation is best NOT used for contrast control although it has some influence. That is what your clock is for.
If you think it does more than this, you are not following good science. Pick something that works, and it will work with all common developers.
