Q qruyk12 Established Local time 5:48 AM Joined Oct 4, 2006 Messages 130 Location Canada View My Gallery May 10, 2009 #1 Make any difference if you keep the shutter wound or relaxed when you are not using it? Are any springs needlessly stretched when not in use?
ddimaria Well-known Local time 8:48 AM Joined Dec 16, 2004 Messages 242 Location Boston View My Gallery May 10, 2009 #2 I think, in general, its always better to leave any camera or lens uncocked.
F Fraser Well-known Local time 1:48 PM Joined Aug 12, 2007 Messages 1,792 Location Scotland View My Gallery May 11, 2009 #3 does'nt matter.
furcafe Veteran Local time 8:48 AM Joined Oct 31, 2004 Messages 4,401 Location Washington, DC, USA View My Gallery May 11, 2009 #4 See http://www.nemeng.com/leica/006b.shtml Also (Nikon RF shutter is close enough to a Leica shutter): http://www.rangefinderforum.com/forums/showthread.php?t=73038 Last edited: May 11, 2009
R Ronald M Veteran Local time 7:48 AM Joined Aug 17, 2005 Messages 4,813 View My Gallery May 11, 2009 #5 Leica will tell you it does not matter. The springs are engineered to take the slight tension increase. It has been written wound is better as the take up drum is larger causing less stressto the shutter cloth over time. It is probably a toss up as neither is perfect. I have always gone for uncocked and have never had a problem.
funkaoshi Well-known Local time 8:48 AM Joined Jan 17, 2008 Messages 323 Location Toronto View My Gallery May 11, 2009 #6 As I understand it, the springs are always under some amount of tension, so it doesn't matter one way or another.
