Lightmeter recommendation and can I use it this way?
ymc226
11:35 PM
California
Just started using a RF along with a Pentax digital spotmeter but find that I do miss opportunities quite often.
Presently, I spotmeter a patch of my subjects skin and overexpose 1 stop to put the skin in Zone 6.
If I am in the same ambient light as my subject, can I just take a reading near me without walking over to the subject and overexpose 1 stop to get about the same result?
If so, can anyone recommend a small and sturdy easy to use incidence meter that is available new or used?
I used to find that provided I was in the same ambient light as my subject a reflective reading with my VCII off the back of my hand was nearly perfect. Since getting my L308-S Sekonic which reads ambient I've done a comparison and the back of the hand method was less than a third of a stop different.
Find a new or used Sekonic 398 incident meter. No battery required. On the street, take a reading in the shade and a reading in the sun and use those. No need to meter every shot. Spot meters are not meant for street work - too slow. Meter less, shoot more.
Morry Katz, Lethbridge, Alberta, Canada
Why do you "miss opportunities quite often"? Spot meter too slow? If you go by the "zone system", I'd say you need a spot meter.
You can do what Keith does, in effect turning a reflected light meter into an incident light meter. Remember, though, that while skin colour differs widely, the reflectivity of the human palm is pretty much the same across races. When I had SLRs with TTL meters I used to meter my palm and add one stop. Now I use film only in an M2 and use an incident light meter whenever possible (it's a slow working one so I shan't recommend it).
Lots of stuff going on here.
* Yes, you can do zone system with 35mm film. You can do it with anything.
* If you're doing zone system, speed is not your friend.
* Zone system and street shooting probably don't match.
* Metering your own hand is great if you're in the same light as the subject. If you're not, it isn't.
* If you're metering for skin tone, not everyone has the same skin tone. We're not all the same color, you know?
Suggestion - use a spotmeter for Zone system, but not for street photography. For that, use an incident meter or reflected light meter. Also consider making use of prefocus.
I don't do pure zone with the photo but using the Digital Spotmeter and Lambrecht's Zone Dial index to place the skin tones usually in Zone 6. There is not time to check for placement of other tones given the nature of what I shoot (candid shots of my family)
I want to get a small incident meter and just meter in the shade and in the open as Morry suggested but the dimensions on the Sekonic 398 look as big as my present meter. I was hoping for something smaller.
For those that have used the Sekonic L-208, has it been accurate enough and there were questions about the durability and battery contacts from long ago reviews. Have these been addressed?
Also regarding the Gossen Digisix, battery life was an issue. Is this also a popular small meter? Are there others?
I remember the documentary "War Photographer", wherein James Nachtwey uses a handheld meter with his high-end Canon film and digital SLRs. He uses something that looks like a Sekonic incident meter; while facing the scene he holds it up in his right hand so the meter is capturing light from the same angle as the camera, over his right shoulder, then sets his camera accordingly. And he doesn't appear to meter every scene, only when the light changes. That's a great film to watch, just to learn these little tips.
Off-topic, but every time I see Christianne Amanpour on CNN, I'm reminded of having seen her in this same documentary, in the part where they've uncovered rotting corpses of war victims in the Balkans, chain-smoking cigarettes like a fiend; I would, too, if I've seen what she's seen. I wonder if that's how she maintains the resonant timbre of her reporter's voice?
~Joe
You worry and obsess too much. Get a meter and live with it. They all work great.
Dear Bill,
(Referring to highlighted portion): Yes, but only if you adjust development for the whole roll to match -- which (I suggest) is unlikely. What you need is a development regime which ensures that most negs print on grades 2 or 3.
Otherwise, we are in complete agreement.
Personally I just carry an old GE PR-1 selenium meter that works great. It's small enough, and the table of exposures on it is very handy. I'm no expert, but even when I don't carry a meter I rarely mis-guess so badly that I lose a great shot. Sometimes it's not absolutely perfect exposure, but it's good enough to not matter. Particularly for things like candid shots of your family I think you ought to just skip the meter completely.
Karl
meters...
meters...
Thanks for the discussion, I learn new things every day on this site. Now I have to look into the zone system to see what I have been missing all this time.
I recently got back into film photography and was carrying a sekonic 328 around with me everywhere, metering everything- too big and too slow. I picked up a second hand Sekonic L-208 recently and love it. It fits in a shirt pocket and meters reflected or ambiant light, is quick to use and read. Now I meter two to three times per roll and hope for the best, as I am slowly getting better at figuring out what adjustments to make on the fly.
Good luck and thanks for starting this thread.
Matt
Thanks for the discussion, I learn new things every day on this site. Now I have to look into the zone system to see what I have been missing all this time. . . . Good luck and thanks for starting this thread.
Matt
Dear Matt,
The Zone System appeals to some more than others. You might (or might not) find the following piece on the Zone System interesting:
http://www.rogerandfrances.com/photoschool/ps zone.html
Roger
Your metering approach here is entirely consistent with page 9 of the manual for the Weston V meter, which recommends taking the reading up close to the face of the subject person, then opening up one stop (or aligning the meter index number with the "C" mark) to double the exposure. There's nothing wrong with your technique excepting it is slow, as you have noted.
It's a shame that some have pooh-poohed the use of a spot meter and zone terminology. Of course it depends on what you've metered - with a spot meter you can be pretty selective about that, and with an aid like the Lambrecht scale on the Pentax digital spot meter you can determine an exposure that will place (for example) those shadows beside the boulder in Zone 3 - "The darkest tone with texture and detail" to borrow Roger's phrase. You don't have to use a full-blown zone system to get benefit from understanding the principle of placing tones - it is much the same in effect as taking an incident reading (or an averaged reflected reading) and using your judgement to compensate for backlighting or an overall bright scene. The spot metering technique is simply more precise and deliberate. And while varying the development time of individual negatives (possible with sheet film but not roll film) will allow you best control of highlights while achieving good shadow detail, you don't need to go to this extreme to get benefit from understanding the use of a spot meter.
But yes, probably too slow for most in street photography (although I do recall Raid uses one, or did). I like the Sekonic L308 for incident and averaged reflected readings - it slips easily into a pocket and uses a AA battery. I like the fact it is not so small I am likely to drop it.
Hi apologies if this is a stupid question, but I noticed that my SLR, my Bessa and my lightmeter gives different readings, eg if I meter an empty white wall with all three. Is this meant to be or its a calibration problem?
