crop factor original pen lenses on ep1 ?
Wouter
8:28 PM
João Pessoa - Brazil
I have some questions here. Considering the fact that the original pen lenses were designed for half frame, would that eliminate the 2x crop factor when used with the ep1 ? In other words, a 35 would still be a 35 ?
The half-frame Pens' frame size is not the same as u4/3 & 4/3, which are effectively 1/4 frame. That is, if you take the original Pens' frame and divide it in half, that's u4/3.
~Joe
True. The 20mm Pen lens, on a Pen FT, is has a ~28mm field of view (about 1.4x crop factor.) On the m4/3 cameras, it's a 40mm field of view (2x crop factor.)
taken with 25/2.8 @8
I find the Pen lenses very fine partners to the G1
