Another stupid, stupid, stupid
Sparrow
9:27 AM
Perfidious Albion
Anybody know what would happen if some fool puts Fuji superia 1600 in a Oly mju/stylus epic? the f2.8 one with the spot meter.
I suspect I’ve done something silly involving the DX coding’s default, rather than the camera being faulty
I know nothing about these cameras, but came up with this after a quick google search. Any help?
http://www.olympusamerica.com/cpg_section/cpg_pressDetails.asp?pressNo=11
Film Speed Range:
Automatic setting with DX-coded film with ISO 50,100, 200, 400, 800, 1600, 3200. For non DX-coded film and film with less than ISO 50, film speed is automatically set to ISO 100.
Only issue you could have met is your film is exposed at box speed. If I'm going to use 1600/Mju2.8 combo anywhere except bright sunlight (which I don't) I rate it at 800 (some scratching and taping involved).
Film Speed Range:
Yep, thanks ... I couldn't find that
So it should have been OK, I have 3 rolls of 1600 that have lots of camera shake and are over exposed and 1 400 that looks normal (for me) all shot at night with the flash off, I thought it may have miss-read the code, but it would seem not
Fuji 1600 has an effective speed of about 1000. 3 1/2 stop overexposure is a lot, but it's a negative film, you might actually still get some usable pictures out of it. Grainy maybe. You can have it pulled a stop or two.
I just got back some Kodak 100 slide film that I exposed at 800 because of user stupidity. I had it pushed three stops and actually got some usable pictures out of it.
I usually give all dye films an extra stop or so but never bothered with this beeing a DX
I use the camera at night without the flash a lot, with 400 but I do get a bit of shake if I don’t brace it against something, I got the 1600 hoping for a faster shutter-speed to improve the shake but it looks to have gone the other way
I’m a bit of a exposure-slut so I’m not to half a stop, but these are way over 2 or 3 stops.
I probably dropped it once too often
Dear Stewart,
No doubt you know this but I post it for the benefit of others who may not and who are reading this thread:
DO NOT overexpose Ektar 100 by the usual 50-100% (for finer grain and minimally reduced sharpness, but a bigger buffer against underexposure) or the colours go very funny and nasty.
Commiserations on the misbehaving camera.
It isn’t the camera, it’s the photos that are now thousands of miles away that concern me, I only needed two decent shots!
P.S. Never used Ektar … Yorkshireman
