Arca Swiss style quick release plate for the Bessa 111?
anjan
6:24 PM
Does anyone know which Really right stuff or Kirk (or other) Arca swiss Ballhead style camera plate would be ideal for the Bessa 111/Fuji 667?
I use the arca swiss B1 and cant find which plate I should purchase.
Thanks in advance
anjan
I bought a large flat plate from RRS. So far, it has worked on 3 different 4x5 cameras and a Pentax 6x7. I think it's listed in the 4x5 camera section of the catalog.
Call RRS. They are most helpful.
I am assuming the large flat plate was for the bessa? If so, what was the model name/number?
Does it work well and does it have limitations because its not specifically for the bessa?
Thanks
anjan
Look up acratech too. They have standard plates with a raised lip of varying length and they look good and adaptable to whatever length you want under the Bessa III.
For the record..........
The RRS plate mentioned above.
http://reallyrightstuff.com/rrs/Itemdesc.asp?ic=B35&eq=B35%2D002&Tp=
A modified Novoflex QPL 3 plate works also fine. The length is 120 mm and so it fits exactly between the spool knobs.
The plate is quite large and gentian blue. It's not an unobtrusive solution, but it's easy to mill a grove or "slot" in the plate due to its depth. So the camera base is "embedded" in the plate. The plate cannot twist and the lower cover of the camera (made from thin die-cast aluminium) is well protected.
For details, please see attached pictures.
I'm not sure about full compatibility between Novoflex plates and other arca-swiss style systems. Safety pins or -stops will certainly work only within one system.
Regards,
Michael.
Re Venchka's image of a completely flat RRS plate:
I prefer plates with a raised lip to hug the front or back of the camera bottom and avoid twisting.
These are available at acratech and (maybe) at RRS, Wimberly etc. But I strongly recommend a lipped plate. The length should be about the width of the camera bottom, go measure. And all will be fine then ...
I've had problems with RRS heads : my Novoflex plates did not lock in it.
I'm blaming RRS as I've also got other Arca style bits from Novoflex and Kirk that are perfectly interchangeable.
BTW: Kirk make a really nice M6 specific plate.
