More Maitani Madness - OM Zooms
Ken Ford
Refuses to suffer fools
10:23 AM
Central TX, USA
While reading up on short teles I started noticing decent comments about a few of the Olympus 35-70 zooms. I'm not much of a fan of zooms in general and of 1970s-1980s zooms in particular, but it could be a damn convenient single lens to carry on days I don't want to have a full kit with me. (My normal RF kit is a 35mm and a 75mm.)
I see four (?) different MF models that were offered by Olympus:
* 35-70/3.6 constant (f/3.6?!?!?)
* 35-70/4 constant
* 35-70/3.5-4.5 variable
* 35-70/3.5-4.8 variable (Cosina made?)
Are any of these worth considering for a walkabout lens? A few people on pNut are big fans of the 3.5-4.5 version, but I figure y'all have some experience, too.
* 35-70/4 constant
I sought after and finally bought an f/3.6 back when I used OM equipment. It was really nice. Everyone always said it was the best of them. A couple of them were definitely downscale in terms of build quality and optical quality, but the f/3.6 seemed great.
By the way, in film equipment, I went from Olympus to Leica, and the quality difference was very noticeable! I am not sure that is quite so true of other 35mm transitions. As much as I loved the OM equipment, I think the optical quality of the lenses sometimes took second place to the design goals of being small and light. The f/3.6 seemed a cut above, though.
Tom
Tom
I have shotthe 35-70 f4, I have the somewhat uncommon version with a built in autofocus sensor that will allow autofocus on manual-focus OM bodies. It was made especially for the OM-F (OM-30), which I have never used, but it works on all other OM bodies too. Its ok optically. Not the best 35-70 but it isn't soft either, just not ultra sharp. The autofocus one I have is built very well, but the regular version is all plastic and is really poorly made.
I was just given one of the f3.5-4.5 lenses. It is SMALL! Nicely made too. I have not had a chance to shoot it, but I like it already.
* 35-70/4 constant
Had it (the original - not the one Chris is talking about) - hated it. Not great wide open. Very big, surprisingly hard to focus, and it wasn't parfocal so if you zoom in, focus and zoom out, focus is no longer what you think it is. Traded it for an OM Winder 2.
A really small and good carry around kit is OM 35/2,8 (I traded that for the 35/2 but its a pretty darn fine lens) and the OM 85/2.
-Gautham
The 35-80 f.2.8 is outstanding. As good as any prime lens in its range. Only drawbacks are that it is very rare, tough to find and expensive. Got mine about ten years ago when it was about $1500. Now, one could probably sell it for a good deal more.
I think any of the f/2.8 lenses will be too large, heavy and expensive for me. It looks like it's down between the f/4 and the f3.5-4.5 versions - the variable is about half the weight of the fixed.
I've no experience of the 35-70s but I do have a 35-105, and it's superb.
Regards
Richard
I had one but didn't like it: I found the images a bit soft. Having said that, it could have been a dud example and it was the first zoom lens I'd ever owned, so I was comparing it with my small collection of Zuiko prime lenses which I've always thought were pretty good.
* 35-70/4 constant
I've had all three of those, and the f/3.6 was outstandingly sharp - probably as good as primes, I'd say. But the reason I wanted a 35-70 was for travel, and it was a bit big - and I got a good offer for it, so I sold it. (I didn't have the cash to keep too many lenses at the time, but if it was now, I wouldn't part with it).
The f/4 and f/3.5-4.5 seemed quite similar in image quality to me, with the f/4 probably having a slight edge. But the small size of the f/3.5-4.5 won it for me - it's no larger than a lot of 50s, and it makes a great travel lens.
But talking of OM zooms, we shouldn't forget the 28-48/4, which is my favourite of them all (for its combination of FL range, image quality, and fairly small size) - but it needs a hood.
Funnily enough my experience is exactly the opposite - I've two 35/2.8s and the 35-105 is sharper than both of them. Attached was taken on Ektar with the 35-105 at the long end, and prints grain-free and tack sharp at A3. It's pretty much my standard lens.
Regards
Richard
I've used both:
As has been mentioned elsewhere, the 3.5-4.5 is incredibly compact and fits inside the normal case just as a standard 50 mm would. This actually puts the aperture, zoom and focussing rings very close together which is a bit fiddly. It's also a bit tricky to focus at the 70/4.5 end with a standard screen but.... If my example is representative, it's very sharp throughout its zoom range (certainly at F8 and beyond) and pretty free from distortion - I like it.
The later 3.5-4.8 bears an uncanny resemblance to a variety of other named versions of the lens. I'm pretty sure it was the standard lens with the Cosina-made OM2000 and it has a lot more plastic in its construction than any OM lens I've seen. That said, for what it used to cost, it handles quite nicely and it seems reasonably sharp. I seem to recall that mine has noticeable barrel distortion at the 35 mm end but only really a problem if your hobby is photographing brick walls and lens test charts. It's noticeably much larger than the 3.5-4.5 but it does focus very close. (52 mm filters though rather than the usual Olympus 49.)
So not much help here really!! They're both very usable, especially if the price is right but the 3.5-4.5 probably has the edge in most respects.
