andersju
Don't do it! 🙂
Carefully check the quality of the digitized NG collection. I have an old version of it, from the late 90s, and the quality is absolutely horrible. The text is barely readable... I have heard that the collection released in 2001/2002 is no good either.
Looks like a new version is due to be released soon. It'll definitely be much better, but still... 8 DVDs. That should be around 38-68 GB in total depending on the type of DVD. Probably around 1380 issues. So 27-49 MB per issue?
Even if the quality is good, do you think someone will be able to read the issues in 20 years [without going through a series of technical hurdles]? I'm not just talking about the fact that DVDs will be obsolete by then. The actual issues on these collections are usually protected and need to be viewed in certain proprietary software, made for a certain set of operating systems (in this case XP, Vista, etc.), and these will also certainly be obsolete by then.
It's not that they will be impossible to use in 20 years, but it would probably cost time and/or money. No one will find them and spontaneously start reading... (unless s/he's a computer geek with a little patience)
