Arjay
Time Traveller
I thought reverting back to film from digital would be easy - but it isn't:
I've shot several rolls of Kodak BW400CN chromogenic film at its nominal 400 ISO speed, had it developed in my local drugstore and scanned it - with abysmal results!
I like how this film behaves in the higher tonal ranges - very smooth, almost no grain and quite subtle.
BUT when it comes to shadow rendition, my results were very disappointing at first sight: The film is clipping shadows abruptly to deep black, and there is very little differentiation in shadow areas - something I have come to appreciate when I convert digital color pictures to BW. With digitally recorded image files, I can produce pictures with enormously smooth shadow detail - and that's what I would like to obtain using film as well.
BW400CN - by comparison acts very harsh, and it is barely possible to tweak scanned BW400CN pictures by way of scanner DEE algorithms or gradation curves with specific bumps in shadow regions.
Here is an example:
Notice how smooth the bright areas are (light gray floor).
Black clipping problem: Look at the man on the left. His trousers show abrupt black clipping. Note that I applied a gradation curve that is fairly steep in the deep gray to black area in the hope of obtaining a somewhat richer set of shadow tonality values. This is exactly what is troubling me.
Can anybody provide hints how to obtain more shadow detail right from the start?
Should I expose the film using a lower ISO value, or could this problem be due to my scanning workflow?
PS: I scanned using a Coolscan V ED and Nikon Scan software. The scan was performed with 14 bits of data resolution. I used the scanner's DEE function which boosts shadow detail - but that in itself isn't the problem. I get the same clipping behavior if I manipulate the gradation curve instead.
Here is an example:
