Durr3
How do I check for the total shots taken on a M8? thanks
Huh?This Unique Image ID # only equals the # of activations if your current directory is 100Leica.
Huh?
I got an used M8.2 witch were a couple of activations into the 101-folder. My first 4 jpeg-tests were picture 74-77 and the Unique Image ID gave 6a0-6a3 (1696-1699) witch means that the 100-folder must have had 1622 activations before being reset.
After resetting the camera myself the current folder is the 102-folder and now the Unique Image ID equals the sum of the 1622 activations in the 100-folder plus the number activations I actually did in the 101-folder plus the number in the file name of the picture in question.
Huh?
The DCIM standard that governs the file/folder structure on modern cameras defines that images are named along the lines of
DCIM/###?????/????####.???
where the final #### is an image number that cycles from 0000 through 9999, and the first ### is a folder number that starts at 100 and bumps up once every time the #### number cycles past 9999 to 0000 again. Thus, if your images are in a folder "102leica", you add 20,000 to the four-digit number in the image file.
Independent of the card used right?
I didn't reset until a little later, say 1775 or so, but when I did the camera switched to the 102-folder but the unique ID went on as nothing had happened. I used this exif tool (which don't work on the DNG's).So you're saying that after unique image 1699 in folder 101, you did a user menu reset and immediately went to folder 102? and unique image id from exif info did not start at one? (which exif tool are you using?)
If the unique ID were starting from scratch in each new folder I would have had no way to tell. But now that the unique ID just seams to continue, this is the only explanation I can come up with.Since you got the camera at folder 101, how do you know if/where it was reset or if it went through 9999 images for the 100 folder?
Exactly!So you are saying the unique ID # equals to your total acuations regardless what the folder # is?
Maybe the unique ID goes up to 9999 and starts all over again regardless of the current folder-number 😕
Simply take a jpg image, upload to flickr and see meta data.
Nope!Are you mixing up the unique ID in the EXIF-Information of the file and the numbering of the file name?
Yes but the problem is which number of actuations, the number of actuations in current folder or the number of actuations since the day the camera left the factory?Independently of the file name the unique ID contains the number of actuations in Hex-Format.
Nope!
Exactly!
Sorry. This EXIF-attribute is not displayed in flickr.
