beyond
Jason Beyond
Hi all. I just received my Leica IIIF. Am looking for a case. I have gone to have a look at ebay. They have primarily two types. Luigi and Zhou. Luigi is priced out of my range. But I would like to hear from Luigi and Zhou users. Thanks.
35mmdelux
Veni, vidi, vici
Luigi uses the best leather and you get a good swif of expensive leather everytime you raise the camera to take a snap. Not all leather is the same. Hard leather comes form the cow's behind. Luigi uses only the finest.
john neal
fallor ergo sum
I have 3 cases from Mr Zhou (2x LTM + M series), including one of his LTM prototypes, and have found them to be really good quality for the price - and he ships quickly.
I have no experience of the Luigi products, they are out of my price range at the moment.
raydm6
Luigi half-case for me + Luigi strap. Superb craftsmanship, and like 35mmdelux said, it smells awesome! The tactile sensation is also very sensual
Luddite Frank
My "user case" that goes on whatever Barnack is in my kit on a given day, is the bottom half from a Leica IIIg case. ( They have metal strap loops riveted to the ends of the case, and will take a modern wide-strap)
KEH has decent prices on OEM leica cases.
You can also find Leica "half-cases" on e-bay for cheap.
The Luigi cases look stunning, but are beyond my means.
If using an old case, make sure the straps are new; the old ones get brittle and break unexpectedly.
I do not like using cameras "naked"; mine tend to get banged-up that way.
Regards,
Luddite Frank
Regards,
Luddite Frank
furcafe
To 2nd Luddite Frank, there are plenty of inexpensive old cases (usually the original ones that came w/the cameras) out there, but the small leather bits tend to get dried-out & brittle.
Another pricey option are the Hirano cases from Japan, sold via Japan Exposures:
http://www.japanexposures.com/shop/index.php?currency=USD&manufacturers_id=36
They are nice in that they have their own strap lugs if you need them for a camera that has unreliable or broken lugs.
Al Kaplan
It takes too long to change film in a camera wearing a case, whether whole or half. Then you're just exchanging "I want to keep my camera looking like new for as long as possible!" for "OMG! What if I scratch the leather on my new case?"
If you actually USE your Leica on a regular basis it won't look all that different after forty or fifty years than it'll look after five.
payasam
a.k.a. Mukul Dube
Screw Leicas are small, so cases might help those people who find them hard to hold. A case should also reduced shutter noise somewhat. Other than these possibilities, cases are no more than decoration. But people spend millions on jewellery and thousands on clothes, so why should they not spend hundreds on stitched leather?
ZeissFan
Not to be too sarcastic, but if you can afford a Leica, then surely you can afford a Luigi.
Adding to this, I've heard nice things about the Zhou case.
Al Kaplan
Get with the times, Mukul. We no longer say "screw Leicas". The current terminology is "thread mount Leicas". But maybe we should say "screw Leicas", purchase some cheapy digital point & shoots, and just get on with life!
beyond
Jason Beyond
Thanks for the feedback guys. I saved a long time to buy the Leica. I m just a young working adult. Will go for Luigi once I saved enough.
By the way, raydm6, what finder is that? It looks good. I have a multi finder. But I find it to be a little too big. Yours is nice.
rya
I use a Luigi case on my M sometimes just for the built in grip. I have very large hands and it makes it easier to handle, especially with a CV 35 Nokton 1.2 attached.
raydm6
beyond said:...By the way, raydm6, what finder is that? It looks good. I have a multi finder. But I find it to be a little too big. Yours is nice.
beyond, that is a Leitz 'SBOOI' Bright-line finder for the 50mm focal length (some are marked 5cm). They came in various configurations (in terms of the outer-casing design). Just do a search on the internet for "SBOOI" and you'll see some examples. They can be pricey. Mine is a mint later version (with serrated finger grips on the side).
Here's one currently at $26 w/no reserve
Here's a small write-up on the Leica FAQ about the BL finders.
BTW - in my photo above (lower right corner), you'll also see a BL finder for the 90mm focal length (SGVOO). I also have one for 135mm (SHOOC). Both have a distance ring dial that pivots the finder (ever so slightly) to compensate for parallax error.
- Ray
flip
良かったね!
While not "Leica's", I use Niccas (a slight improvement, IMHO ;-). Personally, I find that the case detracts from the compactness which draws me to the camera. That said, There are cases for Niccas and Leotaxes which may well fit a Leica. Hard leather. Less expensive.
Mablo
I have an unused black Zhou half case for IIIc/f/g bodies if someone is interested.
Philip Whiteman
The Zhou is certainly well made and is a good fit. It can be un-poppered quickly for film changes. Can't make any comment on how well they last, as I've only had mine since September.
brachal
Refrigerated User
I keep my IIIf in a Domke wrap when it's not in use. Nothing if it's around my neck.
Ade-oh
I have Zhou case for my IIIc and an 'Artist & Artisan' case for my MP. They're both very well made and I find the Zhou case improves the grip of the IIIc in my big, clumsy hands.
beyond
Jason Beyond
Wow. Many great inputs from all. Thanks. Will decide. Zhou case does not come with a strap rite?
Philip Whiteman
Yes – there's no strap built into the Zhou case. For my IIIC I use one of those wide Voigtlander straps – but you have to trim off the strap's leather 'protectors', otherwise they jam against the case and put rather a load on the lugs.
