- Local time
- 12:08 PM
- Joined
- Jun 23, 2005
- Messages
- 6,270
the excellent mir site has a thing or two about the 35s
http://mir.com.my/rb/photography/hardwares/classics/olympusom1n2/shared/zuiko/htmls/35mm.htm
so according to this, 2 versions of the 35/2.0 are out, not much difference between them. But the 35/2.8 had 2 really distinct versions, as I understand it, there was an early 35/2.8 that was small, weighed less and was a SC lens, whereas after 1984 they produced a much heavier and longer lens that was MC. If you look at the numbers, the difference between these 2 lenses must be huge!
Interested in which version each of you has.
That 28mm f3.5 (late model) is one such lens - tiny, but probably one of the sharpest lenses I've ever used.
this lens is just a mm or 2 longer than the 40/2 pancake... really makes you wonder what the fuss is about for the latter
Compared to the 28/3.5, the 28/2 is "sharper" at each f-stop.
They are all dull when compared to the CV 28/3.5 🙂
this lens is (<s>just a mm or 2</s>)(edit: actually 6mm) longer than the 40/2 pancake... really makes you wonder what the fuss is about for the latter
the price for the 40/2.0, you would agree, is exhorbitant. really not worth it. Goes for $600-700 on keh
chris, could you please check which version of the 35/2.8 you have? I'm still hoping the MC version is better than the more common SC version.
and can the MC version really be that much longer than the SC (G.Zuiko) I wonder.
I'll put the Zuiko 28/2 against any other 28mm. That lens is AWESOME.
let me quote from the above link
[FONT=Trebucht MS, Arial, helvetica]Weight: 240g (8.5oz); older version: 170g (6.0 oz.)
[/FONT][FONT=Trebucht MS, Arial, helvetica]Length: 43mm; older version: 33mm (1.3")
Now that length and weight are really a lot for a zuiko lens, comparable to the 50/1.4!
[/FONT]
Doesn't it look familiar ? I think the author has just copy-pasted it and forgot to edit.Length: 43mm older version: 42mm (1.7")
Weight: 240g; older version: 230g (8.1 oz.)
