SLR Nikon 50mm f/1.4 lens
colyn
ישו משיח
12:37 PM
CowTown, Texas
I have a damaged Nikon (not Nippon Kogaku) Nikkor-S 1.4 lens that was factory AI'd and now have a chance to buy a non-AI Nikkor-S cheap and hope to be able to use the aperture ring on it. Will all of the non-AI 50mm f/1.4 Nikon Nikkor-S lens take the same AI ring or were there different ones?
My s/n is 12059xx
I've got these sites bookmarked but they don't have the info I need.
I don't need the conversion ring since I already have it on the defective lens. I can remove it and place it on the new lens if it fits but some lens of the same focal length require different rings and I was wondering if the Nikon (not Nippon Kogaku) Nikkor-S 50mm f/1.4 lens used the same ring..
Colyn,
The list has the information that you seek. Look at the serial numbers of both lenses. Are they in the same range on the chart? If so, then you are fine, the transplant will work. If not, then you need to get a good fine screw driver, after looking if the screws are in the same place on each lens and give it a try.
B2 (;->
Colyn
Just contact Roland Vink the site owner with your question. He will likely have the answer if you come up with a dead end extrapolating the info as B2 says.
Bob
Colyn
Bob
I've sent him 2 emails in the last month with no response. I just sent a third email..
Colyn
Something must be up with him as he usually has responded fairly quickly to the odd email I have sent him.
Bob
Yours is a type 6. As long as the new lens has a serial between 635511 and 1613735 it will fit. The later range C lenses are identical apart from the black paint and the coated optics. Best info I could find
