Zeiss Ikonta 521-16 information?
Mablo
5:01 PM
My first folder. I managed to buy it on the *Bay for a price of few Mojitos 😀. The lens is 75mm Tessar and shutter is Compur-Rapid. I assume it's 6x6. Seller says the camera works but we'll see about that when it arrives.
I know it's between Nettar and Super Ikonta but that's about all I know. Can someone share some experience about this Ikonta? Any quirks I should know about?
This is a postwar camera that replaced the 520/16. Zeiss Ikon always used a "/" rather than a "-" in its model numbers. Small thing, but it does help you to correctly identify camera models.
The Ikonta "B" was produced from the late 1940s to the mid-1950s. Most of these you'll see with either a Novar or a Carl Zeiss Jena Tessar. Occasionally, you'll see one with a coated Tessar -- the same lens that's on the Mess Ikonta 524/16.
I think that if it's a CZJ lens, it should be marked in centimeters. Zeiss Ikon used many of its uncoated prewar lenses on cameras immediately following World War II until Carl Zeiss was able to get enough capacity.
Like all Zeiss Ikon folding cameras, they're very well made. This particular model seems to get a lot of small bumps under the leather at various spots (not just over the rivets).
As long as it's not been dropped, it's an excellent camera. I guess you can say that about nearly all cameras.
Yes, the Zeiss Ikon 521/16 is the Ikonta B.
It's a nice small 6x6 folder. I have a post-WWII model with a Zeiss-Opton Tessar 1:3,5 75mm and a Compur-Rapid shutter. Produces fine images on 120 rollfilm.
The viewer is from the fold-type so it's not that accurate but the medium format allows for some spare space around your subject.
The Ikonta B has a Double Exposure Prevention mechanism so you have
to transport the film before you can use the shutter release button.
Transporting to the next frame is with help of a red window in the back
and numbers on the films backpaper.
I nice feature are the 2 ears to attach a belt. So you don't need a case
to carry it from your neck.
To insert a filmspool you have to open the back and pull the roundels on the bottom plate.
Only things i miss on this folder are a rangefinder, accessory-shoe and a
Depth-Of-Focus scale.
The shutter has a Flash-unit contact but i'm not sure if this is allready a
X-contact (for electronic flashunits).
My Ikonta B has an aftersale fitment of an accessory-shoe. Looks a bit strange.
Hans, that's a very nice Ikonta that you have, and with the coated Tessar. You're right -- the accessory shoe seems out of place.
Hi Sevo,
Think i will try to determine the flash contact (if it still works) on my shuttertester.
The Ikonta B is a relative old camera (about 1948-1953) so chances are that the
contact is still not adapted for the immediate Xenon flash-units (X-contact).
My Ikonta B has no switch to choose between M and X.
Edit : Just did a test and the time-delay is minimal between 0,5 and 1 milliseconds so it indeed seems to be a direct contact.
Regards,
Hans
If it can't switch, it is the same as X. X is the original "synchron" contact without delay or advance, for long time flash with bulbs. Extra settings for small bulbs with a variety of timing protocols were a later development, and only start to appear after WWII - when they came up, "sync" was renamed to "X", older shutters had a nameless or "synchron" socket.
The earlier way to predelay for short flash with bulbs, common on Makinas and Speed Graphics, was to trigger the camera from the flash through a (slightly delayed) solenoid.
Cheap M only shutters later on appeared on many of the low end "cube flash" point and shoots of the fifties to seventies, but these one to four speed shutters can hardly be mistaken for a Compur.
Sevo
Here is my new Ikonta 521/16. It's a bit rough on the edges but bellows seem to be light tight and shutter works pretty well. The Tessar lens is clear and clean too. I'm waiting for milder weather to take it out to burn some film.
Thanks guys.
Hans that is just some random hood that I yanked under the camera to get it positioned better 🙂 Speaking of which, I assume the original hoods are few and far between. So what do people typically use as a replacement hood?
Hans, thank you again. Folders are new to me but I find them really fascinating. Mike Elek's pdf is really useful. If I read it right in my case (ZI 521/16, Tessar) I'll need either 32mm slip-on or 35,5mm screw-on filters/hoods.
My folder story continues:
I shot a test roll with my new ZI 521/16. Unfortunately the results were a mixed bag. The camera is light tight and shutter speeds seem to be right but my photos were curiously soft and not at all sharp. I'm not very sure why this happens. Maybe some haze in the lens or the lens focusing mechanism is not right - or both.
I'm collecting courage to remove the lenses for cleaning and trying to understand how to collimate the lens. Don't hold your breath yet, it might take some time.
In the meantime I found another ZI folder. This time it's an older model, an 520/16 with Novar - Anastigmat 7,5cm/f:3.5 lens and an unspecified shutter (speeds from T/B to 1/300s). It is almost in mint condition from outside, no Zeiss bumps or anything. It even boasts a beautiful brown everready case with Zeiss Ikon logo on the front flap. Unfortunately the lens seems to need some cleaning and the hood is not the same size with my 521/16 so I need to find a new one again.
Let's see what this old lady can do when I load it with a roll of fresh film. My expectations are high.
Hi Matti,
Don't be disappointed with the soft and not sharp photos. Allmost all the folders i bought had problems with the focus and/or dirty lenses. Try to get the focus on infinity right and that will most probably solve the shapness problem.
Thank you Hans. Now I have managed to remove lenses from my folders safely. When I watch the removed lenses closely with a flashlight I can see a lot of cloudy haze. I'd like to sort that out first.
I have Zeiss cleaning fluid and some microfiber cloth. It helps a little but I cannot get all the haze cleaned away.
Any tips for cleaning haze out of lenses?
Hi Mablo,
I myself use ROR (Residual Oil Remover) a lot. Cleans better then i.e. Kodak lens cleaning fluid. When the haze is caused by fungus it's a whole other issue. I myself used Ponds facial Cream a couple of times but there are many other recipes. Just google for "lens fungus removal". Or even better, you could try to find some postings from Fallisphoto in this forum about the same fungus issue. Start with the "non-aggresive" recipes first.
Thanks again, I ordered some ROR. No fungus as far as I can see, just some milky haze.
Next step is the collimating procedure I guess.
1. If the haze has an oil component, then lighter fluid would be the first thing to try. It will dissolve oil fast and (as long as you don't actually SOAK glued-together elements in it for hours) it is very benign.
2. If the haze is fungus, then I would use a 50/50 mix of drugstore hydrogen peroxide and ammonia. That is also benign, and is what Leica recommends for cleaning fungus off of their lenses. It works pretty fast and it actually dissolves the fungus, unlike a lot of the other fungus "cures" you see recommended on the web that just kill it. It is also a heck of a lot easier to clean off of the glass than the next most effective fungus cleaner (Pond's cold cream).
3. If it is tar (cigarettes, pine pollen, etcetera), then denatured alcohol is the best solvent for that. DON'T use rubbing alcohol from the drugstore; at best it is only 90% pure and only god knows what the other 10% is, but it can contain things like balsams and oils -- the idea is to get the crud OFF of the lens, not to put more on.
4. For pretty much everything else, just plain old distilled water and elbow grease works wonders.
Now about cleaning methods:
I would NOT use a microfiber cleaning cloth or lens cleaning papers. A few seconds thought and you will realize that if your lens is dirty, you don't want to trap the dirt between the glass and a cloth and rub it around; that's pretty much asking for "cleaning marks." Many of the lens cleaning tissues (really meant primarily for eyeglasses) are actually abrasive, even without the dirt. I use cotton buds (Q-tips) and I twist them as I wipe, in order to keep a fresh surface against the glass and lift grit away from it. I've been doing this for years, to my own and other people's cameras, and no lens has ever left my hands with more cleaning marks than it arrived with. I do go through an awful lot of Q-tips though.
