t6un
Reading the thread backwards, looks like Brian has stolen both my ideas🙂
Well, Frankie, you are laying it out pretty good here. If there is a viable market for such a thing (which I doubt), then some company with the R&D money, equipment and manpower will be all over it and beat you to market! 🙂
I'm not sure, though, if there are really many folks who want to spend a grand making their old camera a limited functionality digital camera.
A lot of people buy Digital Backs for their old film cameras, and spend a lot more than a Grand on them. They are available for Medium Format cameras, and seem to sell.
Well, if you are confident such a back would sell, just do it! Sure money makers are hard to come by these days. It could be a boutique business like Tom A's Rapidwinders.
I had since bought a late serial number M2 on eBay...cost $800...and started to think seriously...
[I had also found the instructions of how to disassemble the M2 down to the chassis...]
A month ago, I won an eBay auction on an RD-1...first hand learning in how that camera works started in earnest.
[So far no surgeries...if the idea didn't work, I have a nice M2 and a RD-1 to use on my CV 40/1.4 and CV 25/4P. 🙂]
The M body is perfect for conversion because:
[Besides, critic cannot argue my M2d body is flimsy, the shutter no good, the RF patch flares or the RF easily knocked out of alignment... Leica did all of it. 😀 In my stereo-plotter retro-fit days, even Leica-Heerbrugg could not criticize for the equivalent reasons...they built the original instrument mechanics which was not modified.]
- The removable back, once removed, should provide enough room to fit the "sensor package"...including a piggy back PCB and a data-port, mini USB or whatever plug to link up to an iPhone app for chimping.
- A neat enough package will generate interest in the Leica market...especially if the retro-fit can be reversed or removable.
The Epson RD-1 uses an EP-F80 battery [3.7v 1500mAh] that almost fit within the film cartridge space... I am sure a shorter one can be found.
I have also bought a couple of micro-SD readers...8 Gb HC is cheap AND small...fits right over the film transport, or easily within the take-up spool cavity. A clip-on plastic pillow-block is simple enough to make [I have a Unimat lathe/milling machine.]
The M2 body is 33mm thick [not counting the back which sticks out another 2mm]. The M-mount flange to film plane distance is specified at 28mm (27.95mm)...
If I want to keep the M profile, I will have 7mm thickness limit for the sensor/PCB package. If I emulate the Epson out-rigger style [as used to mount the LCD], I mighty have ~10mm.
[The Epson total body thickness is 39mm [as is the M8/9], and would have 11mm to house both the sensor package and LCD. But the RD-1 M-mount protrudes another 3mm, making the net thickness ~14mm.]
The next task: figure out how to fit the package within a space of 45mm wide x 90mm long x 7~10mm deep. Imagine a digital M2/3/4/6/7...
This Md-Package is basically a dedicated micro computer mother board, with a CCD as the only input, no monitoring except a plug, and output only to the SD card RAW...
Cosina manufactured the RD-1 for a MSRP of ~$3500. It would have been decent business if they earn $1000 each piece. That $1000 earnings must also cover CCD, design/development or outsourced PCB...plus manufacturing tooling/labour cost.
KISS.
The first function to support is RAW+daylight only. No JPEG-H or N, straight capture and record onto the micro-SD. Let PhotoShop or whatever is your favourite do the post-processing.
The Nikon D3S sports a CCD with ISO 200~12,800. A good 2 stops better than the M9 ISO 200~3,200...2-bits worth of headroom for pixel-vignetting correction. [Lens vignetting might be variable, but pixel vignetting pattern is constant...regardless of lens mounted.]
I never thought I would hit Leica again, 20 years later...sorry Solms.
TEN PERCENT DISCOUNT! I am ONBOARD WITH THIS!
DCS200c's go dirt cheap. Pick it, or a DCS420c up to play with.
For this kind of project, I think a very simple and straightforward version would be accepted as perfect. Just a back to slap on, as small as possible - and using as little power as possible. Capture in DNG preferrably, but no need for any compensations for vignetting and such. (unless it would actually be possible to buy something like the M-9 sensor from Kodak).
Since something like this would be far too complicated if it is geared to emulate an M9, why not go along with all the people who wants a "digital film" that is dead simple?
What would the price be for something like that, given a production of 100 units? Or 500?
The main cost will be the CCD/CMOS sensor, which can run several $K. I looked at replacing the ancient KAF-1600 with a newer KAF-1603, and it would have been $2,000. The cost of buying a development kit, full-frame CCD and support electronics from Digi-Key is several thousand.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CYII4SC014K-EVAL-ND
SO: step 1 is to find a cheap-enough Sensor, Step two is to get the development kit to do the embedded software and proof-of-concept camera, step 3 is to design a custom board for the electronics/firmware/interfaces, step 4 is a fixture designed around it, step 5 test and debug, step 6 set up for liited production. I still think it is amazing that Leica kept the M9 to $7K.
