I find Pro 800z too grainy for my tastes in colour. I found it quite finicky for a colour print film too in terms of exposure - the shadows block up quite easily in my experience.
Portra 800 (if you can find some)
kodak slide film (E100Gx & VS, if you're steady..)
fuji Provia and Sensia slide film
Fuji 800 / 1600 Natura or Superia (same film I think)
Definitely the slide film in interiors with artificial or mixed light is better handled by my minolta scanner than neg films
I don't use color much at all, but I did buy a roll of Fuji Press 1600 to try out a new CL in a hurry last month:
I'd use it again, though that would obviously entail my learning to expose it properly. I think I was consistently a bit under, using my normal Neopan 1600 nighttime guesstimates and fudges, which generally give me negatives that are a bit over.
Fuji PRO 800Z is amazing. I shot my first roll with it and the color rendition is great, and the grain is pretty good for iso 800. Superia 1600 is interesting for the speed, but it's much grainier than the 800Z...
for slide film, I have bought (but not yet shot, so if anyone has please leave a feedback!) some rolls of Ektachrome P1600, which surprised me as I had never ever seen such a high speed positive film! if that kind of speed is not needed, I'd probably go with Provia 400.
It is a 400 speed film that is designed to be pushed two stops. More or less like T-Max P3200 (which is pretty close to 800, I believe, but will not look up).
I would love to see some results, when you get this back.
I would definitely mark the speed (EI) that it was shot at on the package for the lab, if it were my film. I might also call / bring it to a pro lab in person. It seems likely that failure to push is a point of failure with this film.
