Lord Fluff
Hi all
Can someone who owns either (or both) of the Leica viewfinder magnifiers tell me what the widest useable set of lines is with each?
I'm pondering between the two and wondered whether the higher magnification would render, say, a 35mm lens as impractical to use.
Currently I have a 28/50 setup but am considering options on the long end, and/or adding in a 35, and the working method with magnifiers will influence this I think (eg I may go for a 90 cron if it's easy to use with the higher power magnifier, but it would be interesting to know if I'll have to remove it to use the 28)
Thanks all - hope the above makes sense. If it makes a difference I would be (mostly) shooting without glasses.
