FS Vontz
Aspirer
Isn't everything?
No. Not "everything" is subjective: only some things are, unless one is a die-hard solipsist.Everything is subjective..
No. This is one of the most fatal mental diseases of the age.Isn't everything?
Objectivitity still holds its place in a neo-paranoid New World ...
But, like with repressed mother lust images, the quantitative based technologies of say a Summilux 35/1.4 pre asph, will always have a higher subjective MBS than say a CV 35/1.4, just as Vonage has a higher MOS than Skype.
Yes .Yes, there's an objective reality at the basis of everything whether or not anyone can observe it directly or indirectly.
I'd thought that bokeh was, by definition, purely subjective--an aesthetic consideration of the quality of OOF rendering. However, because bokeh should be largely a result of lens design--given the same scene, two lenses each of different formulae will render the OOF areas differently--perhaps, if one can point to the physical characteristic that produces this sort of bokeh as oppoosed to that, one can then quantify (precisely or approximately) the effect of lens design on bokeh.
Proove it, Ted, via a repeatable blind test. 🙂
I wasn't even addressing you... What happenned here?Okeeey, well if that's your subjective opinion, I subjectively disagree. - You appear to be die hard Reverse Sophist. I'll stick with Occam's Razor and Descartes - thank you very much, as my logical justification for being a Sophist over your logically fallacious "argument" - the good ole ad hominem attack (by direct inference, sophists suffer from "fatal mental diseases" according to you), offered by you to support (rather weakly I might ad) your counter position. And, all this over a discussion about the out of focus areas of a picture?!?! 😱
I din't proffer an "argument"...
Much less, I didn't "attack" anyone.
The syntax in your post prevents me from replyiing, as it is askew.
No offence meant against you, brother, as I don't even know who you are.
All I did was drop a few Kopeks in the RFF piggy-bank.
This might turn rather interesting. However, B XIII referred to solipsists, not sophists, so there's no ad hominem vis sophists, as the reference was only to solipsists who indeed believe that nothing exists outside one's mind, and therefore all is subjective. (I actually like solipsism, as I'm not entirely convinced any of you exist. It's hard to be humble when one is the centre of the universe.)
Question for OP: by black and white, do you mean readings on a pixel-by-pixel or grain-by-grain level?
Excellent. Me too! 🙂Relax - I'm just being a wiseacre, having fun. Don't mind me. All good.
