Sonnar Brian
It's fairly easy to compute the degree of blur of the secondary IR image with a lens that has an IR focusing Index. The blur is the converse of the index. If you use an F2 lens wide-open that has the IR focus index at F5.6, the secondary IR image will be spread across that range of distance. Most Leitz lenses have an IR focus index at about the F2 DOF mark. Others, such as Nikkor, Zeiss, and Canon LTM lenses, are between F4 and F8. It is large enough to show up without pixel peeping. It is blur caused by chromatic dispersion at its worst. Too bad my Calcium Fluorite Pentax 85/4.5 is in M42 mount.
