Lord Fluff
The focus shift IS precisely repeatable
While I don't want to get in the middle here, while the shift itself may be precisely repeatable, the 'lean back' isn't, so that's not a solution I'm happy with.
Is it possible to (simply) explain why the focus shift problem (aka back focus?) is notable on, say, the M8, and not on a film camera.
Yes - the Summilux 50 asph has no focus shift.Thanks Roger, and yes 'ridiculous hassle' does seem quite apt. It also raises the point that if 'most' fast lenses show this behaviour, then that implies that some don't, and obviously I'd like to know which these might be. I think I'd sacrifice a little in 'character' to have a lens that behaves 'correctly'.
Does anyone have experience with a fast modern 50 that shows no shift? It's evidently possible since my 1950's Summarit 1.5 has no such issues....
I used it exclusively at F1.1. It works great. I never stop down. I believe the F1.1 is the only reason I bought it at first place.
LF: I'm surprised you think the original 1.0 Noctilux does not shift.
It's not an issue on film; even controlled testing could not get any focus shift to show up. On M8 it's slight at f/2.8, most noticeable from f/4-5.6, and covered by DOF by f/8.I'm glad to be hearing this about the Ultron as well, as that was on the shopping list as a cheap alternative to the 28 Cron, though I can't believe the shift on a 28 lens will be anywhere near as terrible.
My Lens that i got about 3 weeks ago seems to be free of focus shift, or it's so minimal that it isn't affecting my shooting. However, I usually stay under f4-5.6 so i'm not sure if it's a problem at those apertures.
