Spider67
I liked the Helios 44 (58mm f2) so much I used it for a while exclusively on my Nikons. First on my FG as I could check the DOF via the lens then on my FM. Then I used a damaged sample for a whole year without realizing.
The problem was always with the adapters: The M42 to Nikon (with a lens) worked great with the 58mm but produced very peculiar results with the Jupiter 9. So I started using them on M42 cameras.
There is an Industar 61 L/D for M42 with a deeply recessed front lens (bit like a Micro Nikkor for dirt cheap), Its aperture setting can pe a bit of a pain put I like the results on my Nikon with color film
