robklurfield
eclipse
nice combo.
Great idea Diaster Area thanks very much and nice design Wayne
I'm still not clear on whether my RFs can use the Soft Releases. I have a Bessa R2C, so is it safe to assume that the Mini also will work on it as it does on the R2A? I also have a Canon 7, a Kiev-IIa and a Kiev-4A.
Thanks, Tom A.Works fine on the Canon 7's and also on the R2C - though occasionally have encountered R2C with a slightly different thread.
New to me Leica M3 DS, sporting a MR4 meter, Zhou case, Nokton 50/1.1, and RFF softie!
Tom,
a bit off topic but since we're talking soft releases here have you had a chance to try it out with the Bessa III? If so, which one would work better, the mini or the regular one?
Why is the orientation of the lettering all over the place? 😱 Is it difficult to make them the same as per the Leica script? Or maybe back out the screw a bit and use red loctite 🙄, or shim the softie a bit? 😀
could it just be that not every camera's shutter release threads are aligned at the same angle 😉
