Hi All,
After a fairly long winter-hiatus I strayed from 5222, investigating Fuji Presto 1600 and Tri-X. I am now going back to 5222, ready to go, and enjoying the warmer weather here. M2 and M5 are loaded with XX, and it's going to stay that way, for most of the season. Yesterday I used the Canon 19mm and the 280mm Telyt on M2, and 135mm Elmarit and Canon 85mm F1.5 on M5. Next I want to investigate the Leitz Beutler developer.
Beutler High Acutance Film Developer is a compensating developer that gives excellent sharpness, medium grain, and low contrast. With 200 ASA and slower film a high degree of enlargement is possible. Compensation and lower contrast is achieved because more bromide is released in the highlights than in the shadows. The excess bromide in the highlights slows their development relative to the shadow areas where development continues and brings out fine details. The net effect is an increase in shadow detail, and a decrease in the overall contrast of the negative. A Mackie Line is a fine black line around the highlights. These fine lines result from bromide spreading around the highlight. At the edge of the highlight, the concentration of bromide on the shadow side of the edge causes abnormal restrainment. Consequently, the edge of the highlight becomes very well refined. This metol based developer is very economical.
Beutler High Acutance Film Developer (Neofin Blue Formula)
Solution A
375ml Water (120 degrees F)
5 g Metol
25g Sodium Sulphite
Water to make 500ml
Solution B
375 ml Water (120 degrees F)
25g Sodium Carbonate
Water to make 500ml
Mix 1:1:8, 11 minutes at 20C for XX. BTW I remember buying premixed Neofin Blue concentrate, it came in tiny clear dark blue vials, like little blue test tubes. I think it was Tetenal?
