Rob-F
Likes Leicas
I just shot and developed two rolls of Delta 3200. My goal was to discover the true ISO of this film and shoot it at that speed. I shot one roll at around EI 1000 plus or minus 1/3 stop or so, and developed in DD-X for 7.5 minutes. Good shadow detail, but the negs were flat. So I shot another roll at 1600, and 8 minutes in DD-X. I got very printable negatives, though still a little flat--best results were obtained at grade 3 on Multigrade IV.
So here's what I'm thinking. Delta 3200 is designed for push processing. Most people say its true ISO is 1000 or so. Then I though about Ektachrome EPH, P1600. It is really an ISO 400 film, designed for push processing. If one were to actually shoot it at 400 and process without a push, the images would be flat. The film is deliberately made to be flat without push processing.
I suspect that is what they have done with Delta 3200. Sure, you could shoot it at the true ISO to get full shadow detail. That was my original intention. But I think they designed it to be flat at its true ISO so that it would push well without building excessive contrast. I don't think it's meant to be used at 1000 or 1250 or so. They meant it to be shot at and processed for faster speeds, and designed it to look good at those speeds. So I think I will shoot my next roll at 2000.
If you are wondering why I don't just shoot it at 3200 and be done with it, I have already done that. I though the shadow detail was lacking. Thin negatives. Hard to print. So i'm experimenting to find the best use of this film. I'll try it in XTOL and Microphen as well. But as for DD-X, i suspect it will look best at 2000 with the development extended to 10 minutes or more.
Your experiences?
Your experiences?
