J-9: History repeats itself - or return of the amazing russian lens!
Krosya
Konicaze
10:18 PM
USA
A while back I used to own a black LTM Jupiter 9 - 85mm/2 lens. After a minor adjustment it was a very nice performer. Due to it's long focus throw I sold it and shortly started missing it. It got to the point where I just missed it so much so I ordered another one from Russia via ebay. This one is a silver one, older and pretty clean for it's age. Took a while for it to cross the big blue ocean, but it finally made it to it's new home. At first it didnt focus correct - had a serious back focus:
After a quick re-shimming here is what this lens is capable of:
All shots are wide open at f2 on RD1S.
Amazing lens if you ask me!
A nice performing well rounded lens, aren't they? I have one in Kiev mount so no shimming was needed.
Bob
At first my "models" did Ok with me testing my new J-9 on them:
Than I started getting "bored" look:
And finally - that " if you dont stop - you and your new lens will go out of the window" look 😉 :
So see - J-9 has it's dangerous sides too 😉
Yeah, I think so. It does need a shade though - when you shoot into the sun it flares some:
yet all in all not too bad:
Here is the lens:
and after shimming (just added extra shim) it's F-stop mark ended up on a side so I had to make a new one and re-set the f-stop ring to a new position to adjust for that:
I suppose I was lucky - all it needed was to unscrew the front section - entire optical part and shim it to be a bit further from a film plane (I happened to have a right size shim handy from some other lens I used to do some work on) and focusing part actually does focus correctly - I didnt need to take that apart - thats the more complicated work. I have done that on my previous J-9 and while it's not too hard - takes some time to do right. So, in this case adjustment was very simple.
Well, I'm baffled. I've tried with several experts to get my LTM Jupiter 9 to focus on my Leicas, but it won't focus both infinity and 1.15 meters. I dearly wish it would. I know that Brian Sweeney, who should know, tried mightily to get one to focus over the full range and found it could not be done. Perhaps it is somehow a matter of variances in individual examples, but I'm not sure how that could be, although focal lengths do vary. Does anyone really know?
I don't think you can
🙁 I don't think you actually can get a screwmount J9 to focus correctly at both ends on a Leica or Canon by simple shimming. The reason for this, I was told, is that the J9 focusing mount is designed to work on a Russian LTM camera, which itself has a RF designed for a 52mm lens, rather than a 50mm one as is the case in a Leica or Canon. The 50mm indication on most FSU 50mm lenses is marketing rather than science. The J9 contains a cam which translates the amount of extension needed to focus its longer focal length to the extension needed for a 52mm lens and applies that to the RF cam. The RF, of course does not know what focal length it is working with. This small discrepancy is enough to make a difference with a fast longer lens like the J9, and isn't great for the J3 either. so you can reshim to focus bang-on at only one distance.
I have heard some of the braver contributors to this list talk about taking the lens completely apart and re-machining some inner bits to slightly change the focal length, which is supposed to do the job, but I don't remember how to do this. No doubt someone who remembers how will show up.
Dez
http://www3.telus.net/public/rpnchbck/checking lens working distance.html
here is directions on how to shim ur jupiter 9 ... so to make it easier to cut the shims... I just placed one of the shims on a piece of duct tape so it sticks to the ring.. then take a razor and cut it carefully around the shim... this thickens the shim.... Mine had 3 shims... so if i did need to make it shorter i could have taken out a ring and added the thickness to the remaining 2 shims..
great shots!!
Dez
Well, maybe. Or maybe not. I heard that there are different versions of this lens. I used to have a later, black one that was from late seventies (if I recall correctly). That one I did have to take completely apart and put together differently so it would focus correct. That process does take a while, but doable.
With this lens, I'm guessing, it's focusing and optical parts/sections were already put together correctly and all it needed just to shim it. I could be wrong, of course. I have not had time to check it at every possible distance, etc, but it seems to work at close, medium, medium-far and very very far(infinity) just fine. Or at least as far as I can tell from the pics. There is of course always a focus error with such a lens when wide open, but I can tell you that so far - it's not just me getting lucky with focusing it, but pretty consistant with at least 90% or more hit rate and any distance I have tried so far. There may be some focus difference at some point, but either not enough for me to see it it it's so small - it's covered by DOF even at f2. To compare - I have about the same hit rate or worse with Nikkor LTM 10.5cm/2.5. So, it seems to me - it performs pretty good - J9 that is. 😉
Yeah I have a black one from the mid 80's all it really needed was some shims... I've checked it with a focusing chart at 3, 6, and 9, feet and checked infinity... seems to be spot on... time will tell ....
Has your wife talked to my wife or something? Although in my case it was something like over the deck railing. 😀 😀
The J-9 is a nice lens. I have it in Kiev/Contax mount as mentioned above, so no problems.
Well, I finally got around to developing and scanning some film. While all of the above pics were from RD1S and J-9 - here is how this lens looks on film. I used Bessa R3M 250 Jahre camera and Kodak B&W film. Home developed and scanned (sorry for some dust and water spots), but this lens keeps amazing me - I think I'll be selling most of my long lenses soon, as this one is just one awsome lens. Well, see if you agree:
I have a J9 as well, it was not accurate in focussing so it made it's way to the back of the drawer for over a year.
However, not I have a GF-1 I don't care about the inaccurate RF cam coupling - perhaps with the m4/3 cameras there will be more of these coming out of cupboards.
Easy
Easy
Hi, great lens, i´ve wondering about an elmarit but your beautiful and sharp shots have made me change my mind!
I had problems focusing a j8, no reshimming but had to make elements closer, that was major surgery or better said butchery, at last it performs very well!
it´s easy to do it with a digital m mount camera!
Bye, excellent photos and results!
