Bill Blackwell
Leica M Shooter
Bill. I find that the 15 sees a bit more use, could also be because of the 52mm size. The 15 is wide - the 12 is REALLY wide. With the 15 you can work as if it was a wide 21. The 12 is a speciality lens - but when you need it - there is no substitute!
Thanks, Tom.
Anyone have any thoughts on coding the CV 12/5.6 for use on the M8 or M9? ...
I would think the best you can do is code the 12 as a WATE.
As to the 15 coming up as an 18, I used to have that happen all the time when shooting my M8. If I happened to remember I switched it to properly indicate the 15, but there never seemed to be any effect on my pictures (other than the exif data).
