Rodluvan
Looking inside, I don't believe it was the best thing to do. What a tangle of wires and circuitry and fine mechanics!
The problem was that I find it underexposes by at least 1 stop inside (st to 'inside'-mode) and by very many steps outside even though the battery checks out fine.
johannielscom
Snorting silver salts
I've taken apart several too, but sadly never put one back together.
You have my sympathies
Rodluvan
The thing one pushes in front of the window (where it lets the light trough to meter) is it just a thin semi opaque plate of sorts?
What am I to focus on if I just want to make a CLA of the Meter? I suspect that is all that is needed to make it meter correct.
Rodluvan
Wow, this doesn't sound so good. What do you figure my odds are?
Beemermark
Generally all the meter needs is a good cleaning and adjustment. I haven't done one in years but I have done quite a few in the past. Remove the cover, clean with a good electronic cleaner (they used to make one for cleaning TV contacts that didn't harm plastic). Try Radio Shack.
HuubL
hunter-gatherer
Make photos during the proces of dismantling and when putting things back together. These may be handy as a repair manual for others. Good luck!
John Lawrence
When I was tempted to take mine apart, I found these links very helpful:
http://feuerbacher.net/photo/frame.html?repair/Leicameter/Leicameter.html~Main
http://photo.net/leica-rangefinders-forum/00DlEP (scroll down about half way)
Although I changed my mind (being of a nervous disposition!), you may find it useful.
John
John
Rodluvan
John
Oh, man! That's simply awesome! thanks a million. Here goes nothing....
Rodluvan
Wow, not to beat my own drum, but by the looks of things <i may just be the first person on the face of the earth who successfully took a Leica Meter apart, repaired it and put it back together again
Thanks for the links, without them I would have been completely lost.
johannielscom
Ziploc bagged MR meters shall rise again!!
John Lawrence
Glad they were of some help to you.
John
Rodluvan
Just developed my first roll using the Meter and it's on the button. Couldn't expect more!!
John Lawrence
Excellent - and by a strange coincidence I've just given my MR meter and MR-9 battery adapter away this morning and lo and behold they worked perfectly and were accurate. The new owner is very pleased with them - dunno why they didn't work like that for me!
John
John
SolaresLarrave
My M5s need red dots!
I had my two meters looked at by George Milton and they both work very well... but now I admit to having abandoned them in a bag. Must check that the batteries didn't leak.
They are really good and accurate!
Thanks for posting your story... and yes, feel free to brag!
We understand you.
