Do You Compose for the Final Print Format?
JoeV
Thin Air, Bright Sun
5:27 PM
Albuquerque, NM, USA
Aspect ratio-wise, do you compose for the final intended print format when capturing images with your rangefinder camera? Personally, I find that I like the 5x7 format for printing onto FB silver paper, it's big enough to make a presentable image, small enough to overmat, and frames and mats are easy to find in that size. But, I have to crop a bit off the sides from full-frame when printing, so sometimes (if I have time to think about it) I'll step back a bit and go a bit wider in the composition than I'd otherwise intend.
So how about you? How does the anticipation of printing the image effect your composition within the rangefinder's viewfinder?
~Joe
I print a full frame image onto the 5x7 print paper...
This does render a slightly smaller image but I do get the full frame image that I shot in camera...I'm happier this way and as everyone knows it's all about the photographer...
I'm in the same boat as you. Funny, I was printing most of the day today, and was thinking I should post something regarding the 5x7 format. I too really like it, for the same reasons you mention. I've been using Kentmere Fineprint VC, both glossy and matt, and I like them both very much.
I don't consciously compose for the format, but the small bit that does get cut from the sides hasn't been a problem (dramatically altering the image that is).
Cheers
Steven
~Joe
I subconsciously compose in the viewfinder knowing that I will later use whatever aspect ratio the scene needs and not any arbitrary standard decided by a paper manufacturer 100 years ago.
i like the black edges when printing full frame. however, once in awhile, a scene comes up that you know exactly how you want it printed when you look through the camera. i feel proud of those.
but most of the time, i don't stress over framing.
When using an RF, I compose for 3:2 only. Main reason is that I seldom crop my photo's and if that incidentally happens, I crop to 3:2 again as it feels very natural to me.
4 x 6... make people really look at your image and study it.
This puts into words a concept I had and worked with, but never knew how to explain it. Thanks for explaining it to me, Bob! A best answer, for me.😀
The aspect ratio of the camera should be honored. If you shoot square, print square. If you shoot 35mm, then ratios respecting ~ 36x24 make sense. In the end, I'm with Bob (Sepia); full frame.
I tend to compose full frame, sometimes leaving a little loose-room around the edges just to be sure and which can be cropped if needed. I just find the 'classic' frames are too restrictive...when I frame a print I make my own bespoke border to fit the individual image
Hi Joe, I usually print my working prints onto 11x14 FB paper. When I do I print the entire frame and leave a thin black border and some white space around the picture. So it usually ends up being like 10x13.5 inches ...
This way I can study the picture, and decide if I need to crop it, or what. I often just decide that I like it as is, and my work print 'becomes' my final. Yep, I'm lazy.
All great. Unless you want to print on 8x10, use more affordable 8x10 frames or albums in the US.
I sometimes use 90mm framelines and shoot with 75, just because I know I'll print on 8x10.
Roland.
Great responses, everyone. I'm interested in trying printing full-frame, with a black rebate with white border around the image, as some have suggested. I still like the 5x7 frame size, for aesthetic and also economic reasons.
I also do some half-frame shooting; 5x7 is about as much as I'd want to enlarge those smaller negatives.
~Joe
No.
I can show the whole frame, though... But it's relationship between elements what I care for, and I can crop any image without thinking of any ratio or paper size if I feel it helps the image. And sometimes I find an image is better with different limits than those I planned first when composing.
Anyway, I prefer to print as much images with the black negative border as I can: those are the ones I enjoy the most.
Juan
