Can anyone identify this Camera? I want one!!
Pirate
Guitar playing Fotografer
4:48 PM
Highland, Mi.
Saw this photo here on the forum the other day and would love to know what kind of set-up this is. I want this!!
Thanks
Mamiya C220 or C330?
Looks like a mix of old-style design medium format press camera and a comparatively modern electronic flash unit which IMO date the picture (together with the type of foam cup and style of clothing depicted) to late 70ties or early 80ties ... which would be the right period for the Mamiyas.
That must be a Graflex 4x5 camera with a grip and a Metz CT-3 flash attached. Might be a Crown Graphic, with a top mounted Kalart or similar rangefinder.
Doesn't this guy work off Coney Island somewhere? I've seen this rig before...
I am quite certain it is a Graflex Speed Graphic.
More than 50 years ago, I used one when I was a student at the `Massachusetts Institute of Technology and was a photographer for the M.I.T. magazine, and for the Yearbook.
best regards
maurice
Yeah, it's a later Graphic 4x5 with a top mounted rangefinder. I can't tell in this photo if it's a Speed or Crown, the focal plane shutter winding key is not visible but could be blocked by the flash and bracket.
I have two earlier Graphics, one Crown, one Speed. Both have side mounted Kalart rangefinders. The Crown is going "nude" and is becoming a field camera slowly. The Speed is 99% restored. The only things missing are a few metal tabs on the focal plane shutter curtain which trip the flash. These curtains haven't been available for years and so I'm trying to get as much life out of this original one. I may sew some copper foil into the edge of the shutter for the flash synch. Focal plane flash or no, it's still a GREAT camera system.
Phil Forrest
The Pacemakers had brushed aluminum lensboards, not black. The early Graphics and Anniversary models had black lensboards, some had black trim & front standard hardware. the top mounted RF places this as a later model, but he also probably has a few lenses mounted in whatever lensboards he could find. There was a lot of mixing and matching in the factory and over the last 70 years many cameras have been scavenged to make working bodies. I have enough parts to make a third Crown but no body/bed assembly.
Phil Forrest
So what is the best body for building a setup like that?
Speed Graphic
Crown Graphic
Speed Graphic Pacemaker
Speed Graphic Anniversary
I like the idea of a top rangefinder vs. a side rangefinder.
Pacemaker Crown Graphic with a 127mm or 135mm lens.
They are numerous & relatively inexpensive. There are newer lenses that perform better than the originals, but the 135mm in Graflex shutter can still make an amazing image on 4x5.
The Speed Graphic is about 1lb heavier. The focal plane shutter is a benefit in case you want to use barrel lenses that have no shutters. If you never plan on using those lenses then the Crown is definitely the one to get. The rubberized material on an old shutter curtain can and does flake off during exposure using a regular lens in-shutter. It also is a great place for dust to collect and deposit on your negatives.
If you want to go for a real setup that is authentic looking and working, you'll want to find a Heiland Graflite or Graphic Flash synchronizer. They use flashbulbs which can be expensive per-exposure, but sometimes there is no substitute for that amount of light.
It's really an amazing and very capable system.
Start lifting weights! My Speed Graphic + Graphic flash + Grafmatic back weighs about 10lbs!
Phil Forrest
I'd really like to try something like this, but I guess you have to have a darkroom for loading the sheet film and developing it?
