PKR
If they are stitched seamlessly -- and if what you say is true, they must be, or there'd be gaps between the different parts of the image -- then this is a philosophical difference rather than a real one. My own suspicion is that you have misunderstood sensor design, but I don't know enough to assert this with absolute confidence.
As for telecentric lenses, yes, they're better for digital but they suffer accordingly from other problems: as far as I recall, poorer chromatic correction and (therefore) lower sharpness (I didn't take notes when I was talking to Zeiss lens designers about it).
Hi Roger;
If you look at the largest die a fab can produce in the current, world wide standard, and they are all the same, it is far smaller than 24x36. I'm not sure but I think the common FX sensor is at least 4 pieces. The Phase One is a large number of stitched dies.
One of the things that makes all these cameras different is the sensor designers. The people making the dies take the design data and produce a product. I know that Sony, makes the sensors for Fuji and Nikon. This is production, a standard in the semiconductor industry. The sensor design is the work of the camera company. Researching this should be simple. i know that Foveon is doing some layering that is very difficult to produce. I have hopes for them. I asked their designer, jokingly, when his sensor would look like film, his reply was, never, do the math. It won't happen. I don't have a problem with digital looking different. It's better in some instances (my taste) than film. I don't think film will go away. Fuji for one Co. is in for the long term. p.
http://chipworks.com/blogs.aspx?id=4626&blogid=86
There is a decent description at the above site. And yes, there is much "personality" that goes into the design. They are not all the same. This is a good thing; to my way of thinking.
p.
