Vincenzo Maielli
This is simply not correct by any measure. The MP is put together in an assembly-line by unskilled employees. The M4 was put together by highly skilled artisans.
The MP has the same 'right or replace' finder found in the M4-2 (and in every M camera since). The oft talked about (flair resistant) condenser was removed half-way into the M4-2 run and added back starting with the MP. The MP 'build quality' is indeed inferior to that of an M6 - If you want to argue contrarily, no rational case can be made that the MP ‘build quality’ is better by any comparison. The MP eyepiece is substantially inferior to any preceding it.
"I knew the Leica M4; the Leica M4 was a friend of mine. The MP is no M4." Lloyd Benson (well, sort of)
The rangefinder of the MP have the same optical contructions of the Leica M3/M2/M4/M5, this is a fact. See Erwin Puts articles to confirm.
The rangefinder of the M4-2 lack an optical element, in respect to M4/M5 and previous Leica M rangefinders, while another optical glass element was replaced by an acrylic element. This construction was made to pull down the manifacturing cost. This type of rangefinder was mantained, also, in the M4-P, all versions of the M6 and the first version of the M7.
In the Leica MP, and in the Leica M7 from 2885 matriculation numbers, the optical rangefinder was realized like in the past.
I own Leica M2, M3, M4, M5, MP and M7 with new rangefinder type and I confirm that situation.
Ciao.
Vincenzo
