The great filter poll of 2010: UV/NC with vs. without
  • YES! Someone told me to protect my lens with a filter, so I have.
    Votes: 4 5.3%
  • YES! I am compelled to protect the front element of my expensive lens.
    Votes: 27 35.5%
  • YES! I know it may affect image quality, but better safe than sorry.
    Votes: 13 17.1%
  • YES! Supposedly it affects image quality, but I can't see it.
    Votes: 24 31.6%
  • YES! My lens was damaged, so now I always use a filter.
    Votes: 5 6.6%
  • YES! Actually, I see improved image quality with a UV filter.
    Votes: 2 2.6%
  • NO! Not only that, I have never even considered using UV filters.
    Votes: 9 11.8%
  • NO! My lens costs so much, so why put something in front of it?
    Votes: 4 5.3%
  • NO! There's no need; the danger is low and it degrades image quality.
    Votes: 10 13.2%
  • NO! Never, because it measurably affects image quality.
    Votes: 4 5.3%
  • NO! My lens was damaged, but I still don't use a filter.
    Votes: 0 0.0%
  • NO! Except for rare occasions, like one day out of the year.
    Votes: 8 10.5%
  • Total voters
    76
  • Poll closed .
No, because it measurably degrades IQ. I've never wrecked the front element of a lens in normal use, and filters cause all sorts of weird flare and reflections - even the expensive german multicoated ones.
You buy your lenses to take photos with - the photos are the main objective. Why possibly degrade that with something that isn't needed.
That being said I will use one if in really bad conditions - ie: mud/sand/ etc
Measurably??? I have yet to see a filter have any effect. Can you show me some images that give me the occasion to measure any difference? Please? Thanks!
filters can cause all kinds of weird goings on. i learnt the hard way shooting an Oasis show one night.
I think 'ghosting' is one example of the effect of an always-on UV filter, though I have only seen when a lens (yes, a Leica lens) also shows flare. Not a show-stopper for me, though.
It don't happen all the time, but it will have an affect at a certain angle of lights, plus different brand of the filter.
As I remember there was a pic posted on the local forum, it is a sunset shots aiming directly at the sun, and the filter created a double image of the sun.
Visible proof that filters degrade images by flare:
http://www.lenstip.com/113.12-article-UV_filters_test_Heliopan_ES_72mm_UV-0_SH-PMC.html
Look at the second and third pair of pics.
FWIW, B+W MRC showed virtually no impact and Hoya HMC did better than SHMC. Draw your own conclusions...
Personally, I went from using B+W MRC filters all the time and no hoods, to hoods all the time and no filters. I used the filters only for protection, and the hoods did that for a lot less $$$.
I use a UV filter and a hood whenever possible - esp. on my more expensive lenses. A UV lens does produce reflections with stronger light sources (if it's bothersome it can be PS'd out) but I don't think it degrades the image quality (lose detail/distortion) per se. You can see these reflections turn up from time to time in some photos. However, I use a UV not so much to prevent scratches or damage to the lens. I do this more because of atmospheric grit that can accumulate, people sneezing, coughing etc... liquids spilling, etc. It keeps atmospheric dirt and goo off the lens - something a lens hood can't really do.
I should mention that silver filters and chrome filter rings can also cause reflections in strong lighting that show up on your pics. It's rare, but possible.
I once did a test using all my Leica M lenses with and without BW UV MRC filters. The camera was on a tripod and the subject was a book shelf with a desk lamp with halogen bulb pointed at the camera and in the image. Thia was before I had a slide scanner, but as hard as I tried with a high magnification loop, I could not see any image quality difference in the center or corners and no additional flare or ghost images. As a result, I use this type of filter on all my lenses.
I tried a few of my lenses with and without the filter. Can't see any difference in the pictures. Not a scientific test by any means, but enough to convince me to keep them on.
Besides, how come we don't hear a lot of moaning about image degradation caused by the other kinds of filters?
I have no logic - I use no UV filters on my RF lenses, yet use them on all my AF SLR lenses. And my Zuiko lenses but not my other MF SLR lenses.
I do, however, frequently use ND filters on my RFs - that's for genuine photographic reasons (as is my use of circular polarising filters on SLR lenses).
I didn't vote, though. Because nothing really captured my personal illogic.
...Mike
