charjohncarter
One of the best features I've seen on any flash (and on the back of this one) is a scale system for the manual setting. Dial in your ISO, scroll the other wheel around to the distance you're shooting, and it will give you the F-stop to use. I tested this on my Nikon D700 last night and it works like a charm. 6-feet away and 100-feet away, perfect.
And yes, it says in the instructions that it can burn things if they are too close when it goes off!
Flash use is always more accurate when using manual. But like I said you have to use your brain.
