Vickko
Why would any sane person have TWO Focomat IIc's?
Vick
Vick
I have a Durst 900 and a Focomat Ic side-by-side---- the other Ic is as a backup and the IIc I don't use--- as well as a MINOX enlarger on a shelf ready-to-use within a minute...Colour + B+W
Combination printing
Pre-flashing
Using two formats...
...for a start. We have two Magnifaxes side by side and if we could afford it we'd probably have two Focomats.
Vick
The beauty of the modern Durst design is the ease of changing things. To remove the CLS head its unscrew the two screws and lift. Install the Ilford 500.. The same, leaving the same lightbox. Change lightbox.. Just flip the head back (the plate has a hinge). Insert a condensor? Use the shorter light box and insert from front.. Use cold light.. Remove light box and insert cold light (its the size and form of a condenser). Opal.. Insert the mirror... and the correct condenser.. Point-source? Remove the Opal and insert halogen, plug into the Variopoint and adjust--- point source always needs some fiddling and adjustments.My main enlargers are two Laborator 1200's, one bought new, the other picked up used (but still in film days and not for cheap), to switch between condenser and CLS head without disassembling that brute every time...
That's more or less how I ended up a historical Focomat. A friend purchased it from an institute here in Munich but only wanted the masking frame... and well.. I could not see it go into a landfill.. [Quite rare, very special and historically more significant than most WW-II era cameras]Within the past decade a few other large format enlargers have ended up with me when their original owners offered them for free, to be scrapped, but these are in storage or at any rate not set up for immediate use.
